Enco 100-1588 repair
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    Mar 2012
    325
    316
    136
    Default Enco 100-1588 repair
    Our high school has a '92 Enco 100-1588 10x54" mill. One of the students called me over, saying is was vibrating a lot. The head was quite warm. After pulling it apart, I found that the top motor pulley was cracked. Inside the cover was coated with belt dust.
    The set screw was long gone. I've got a new pulley on the way. I later discovered that the motor shaft is a mess. Look like someone took an angle grinder to it!
    The journal at the faceplate has about a thou runout. The low portion of the shaft, where the bottom pulley slides up and down, has about 4 thou runout. I haven't priced out a new motor yet. I'm sure its not cheap, assuming it available. I was surprised when MSC said they had the pulley.
    Is the 4 thou runout too excessive?
    The keyways are not the best either:
    While I have the thing apart, I plan to replace all the bearings except for the spindle bearings. Both belts will be replaced as well.
    The spline on the top of the "worm coupling shaft is pretty worn. Not sure it really need replacement though. We almost never use it in low speed.
    This is the top shaft,
    And the bottom:
    Any comments, suggestions etc are greatly appreciated. I'm not a machinist, just a high school robotics mentor who doesn't know not to take stuff apart! My main worry right now is the motor shaft runout.
    Oh, one last thing. where is a good source for replacement bearings? They are mostly 6xxxZ. I assume MSC is going to charge me a lot more for them. As you can guess, we don't have an unlimited budget!
    Thanks for your help,
    Andy
    Nov 2007
    marysville ohio
    9,790
    2807
    6490
    Quote Originally Posted by ariyama View Post
    And the bottom:
    Andy
    The shaft is toast, time for a new motor. To bad you bought a new pulley, you could have saved the old one by making a steel ring and pressing it on, as long as the bore is good.
  3. Likes Newman109, eKretz liked this post
    Jun 2016
    New York
    1,888
    1221
    899
    Quote Originally Posted by moonlight machine View Post
    haha! how COULD the bore be any good?? virtually impossible.
    try H&W machine repair for the bearings, they seem to sell them for reasonable prices.
  5. Likes TDegenhart liked this post
  6. #4
    Mar 2012
    325
    316
    136
    I thought about doing that, but the bore is no good. I can feel that it is deformed, at least at the top. I suppose I would have had to press a collar on it to know for sure, but it didn't seem likely to me. I'm the only one there to look after the machines. I want to make sure it will continue run for a long time, even if I'm not there to fix it.
  7. #5
    Mar 2012
    325
    316
    136
    Quote Originally Posted by cyanidekid View Post
    I will give them a call, thanks. Their videos have helped me a lot, even though the Enco mill is a bit different.
    Thanks.
  8. #6
    Mar 2009
    5,586
    103
    1079
    I have gone with Motion Industries for bearings. I could call the local office in my city and they would get the bearings on their regular daily
    truck delivery from the warehouse.
  9. #7
    Jul 2008
    South Bend, In
    2,699
    183
    275
    Lightbulb
    And the bottom:
    Andy
    I have a N.O.S. motor from a MSC mill that looks like it could be the same.
    Send me an email with the specs and we’ll figure it out.
    Ted
    [email protected]
  10. #8
    Oct 2005
    17,261
    Another company supplying aftermarket parts for the clones is High Quality Tools, in cleveland, ohio
    High Quality Tools, Milling Machine Parts | HQTInc.com
  11. #9
    Mar 2012
    325
    316
    136
    I stand corrected. There is a lip on the end of the bore, but it is on the outside. Sadly the students destroyed the snap gauge I needed to check it properly. With the calipers it looked to be spot on the 1.1 inch diameter of the of the motor shaft. That does not seem possible given the crack. Of course I have no idea how much runout there is. Still, I'll feel better having a new pulley in there. If it were my own machine, not the school's, I might go that way.
    What would the acceptable runout be for the motor shaft?
    Looking at it more closely tonight, I see the keyways have severely worn sides. So runout is not the only issue.
  12. #10
    Mar 2012
    325
    316
    136
    Default Worn splines
    The the splines the ends of the upper and low coupling shafts are a bit worn; particularly the lower one:
    The upper coupling shaft:
    You can see the wear were they mate ( they are upside down - lower coupler is on top ):
    I think the lower one should be replaced. Upper seems OK.
  13. #11
    Mar 2012
    325
    316
    136
    Default Experience is what you get....
    Yeah, I screwed this one up. I was trying to get the coupler shaft out of the worm housing. The rubber mallet wasn't doing it. Over to the arbor press.
    Then the "oh crap" moment, when I realized I bent what I think is a "spring shim" on the part diagram. I wedged in hard enough that the only way to get it out was to cut it. The damage was already done!
    Experience earned
  14. #12
    Dec 2012
    AUSTRALIA
    2,827
    12
    910
    Despite the peanut gallery ,such things are a simple repair for anyone with a lathe.....skim the motor shaft till its true,sleeve the break in the pulley boss ....bore the pulley boss until the bore is clean .....make a split bushing for the gap, and find or make a wider key and fit it ....press it all together with loctite used liberally.
  15. #13
    Mar 2012
    325
    316
    136
    Default If I had a bigger one
    Quote Originally Posted by john.k View Post
    John,
    If I had a big enough lathe, I would tackle it. The school only has toy lathes. Hmm, I might be able to do the motor at home in my 10" unmentionable. I'll disassemble the motor tonight and see if its possible. Guess I can't make it much worse. I could tig weld the keyway and mill back to size. There is a splined adapter that is keyed on the inside. If I enlarged the keyway in the shaft, I'd have to do it it on that as well, potentially weakening it. Tigging the shaft would likely warp it more tough.
    Thanks.
    Andy
  16. #14
    Dec 2012
    AUSTRALIA
    2,827
    12
    910
    Have a look at an advice bulletin for green loctite and loctite key repair. ...there are lots of suggestions for fixing just such a situation .
  17. #15
    Mar 2012
    325
    316
    136
    John,
    Loctite 660? Found some videos on it. Looks pretty good.
    Andy
  18. #16
    Mar 2012
    325
    316
    136
    Default Motor shaft
    We pulled apart the motor tonight. After we pressed the bearings off, I checked the journals. Well under a thou runout. I didn't have a tenths indicator handy, but I would guess about half a thou. That gives me a good reference surface. I think it worth trying to turn it down, build it back up with the tig welder, and any down to size. If I fail, I end up getting a new motor, which I was going to have to do anyway. Either way I'll learn something in the process!
    The next step is figuring out what filler metal to use.
    (photo taken after the fact)
    This is the splined collar that goes on the shaft. Pretty beat up, and loose on the shaft. I'll try to get a replacement.
    There is a plastic mate to that that fits in the bottom pulley. That is quite worn too. Another thing to replace.
  19. #17
    Feb 2007
    St. George, Utah
    1,032
    564
    686
    Did you see post #7? I'd start there for the motor problems!
  20. #18
    Mar 2012
    325
    316
    136
    Quote Originally Posted by Gordon Heaton View Post
    Gordon,
    Yes, I contacted Ted and he kindly measured his motor. It looks like a close fit, I'd need check my numbers again. His motor is a 2HP, while mine is 3HP. I'll proceed with the repair for both the challenge and the experience. In a commercial setting it might not make sense, but for the school, we have more time than money.
    Andy
  21. Likes Gordon Heaton liked this post
  22. #19
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    3,818
    70
    888
    if the flange and shaft fit i wouldn't be too critical of 2hp vs 3hp . in the 90's , there were many machines
    boasting optimistic hp ratings which included "peak"
    and "15 minute duty cycles" . even a real BPT today isn't completely innocent of the practice .
    putting a slightly smaller hp motor might be to advantage- less wear and stress on an old
    machine , which was already junk the day it left the factory .
  23. #20
    Apr 2005
    Beaverdam, Virginia
    8,113
    913
    3899
    As for bearings if you haven't bought them yet sometimes you can find great deals on Ebay for high quality precision bearings. I scored a matched set of spindle bearings, name brand that are $400 a set at the cheapest from bearing suppliers for $35.
