end mill selection Hardened steel
Likes Likes:  0
Results 1 to 5 of 5
    Feb 2013
    North East
    96
    15
    Default end mill selection Hardened steel
    Help me out here - - What cutter?
    Hardened steel not quite 56Rc but a little harder than 48. It can be filed but not easily.
    What kind of steel? Whatever it is they make commercial lawnmower blades from. 5160, 1084, L6 ? I don't know.
    Manual Mill. Bearings are - - well not shot but not new. I have a Timkin Rebuilt kit. Just haven't installed it yet.
    So what end mill?
    Carbide or Ceramic?
    What flute Pattern?
    How many flutes?
    Will a coating make a difference?
    The pass will be on the side of the end mill about 1/2" to 3/4: wide. Depth of cut in the area of 0.050"
    I am totally burning out conventional 4 flute carbide end mills in like three passes.
    I want a cutter that will last the season. I have become fond of sharpening my Ferris zero turn blades on the milling machine. I get a really nice long lasting edge.
    May 2019
    Michigan
    2,421
    1255
    1783
    Ceramics on a manual mill? You're kidding, right..???
    I have had excellent success with this tool from OSG: ExoCarb WXS
    That said, I don't know how well it would work on a Bport.
    May 2011
    New Jersey
    2,635
    250
    1417
    5 or 6 flute carbide AlTiN coated .03 radius...sit it around 1000 rpm and feed it fairly hard.
    Aug 2004
    Virginia
    2,629
    198
    1119
    Seems a bit overkill for lawn mower blades but if you want to do this then carbide is what you should use. You might consider a cup wheel instead. These are not microtome blades.
    Jun 2019
    599
    233
    663
    So you bought the wrong blades and didn't want to drive all the way back to return them too huh?
