zimbo
- Apr 22, 2017
- Richmond, VA
I hope I can express myself clearly on what I am wanting to build and hope its in the correct forum.
I would like to build a hand held chemical drenching gun that will squirt out liquid around the stem of a plant. The amount of liquid needs to be calibrated to a predetermined amount per plant ranging from 5-12mls per plant.
I had used an automatic livestock vaccination syringe back in the 90's but they were expensive and required a lot of maintenance, esp. the rubber seals on the plunger and valves. The employees' hands and wrists also suffered from fatigue a couple hours into the shift. Carpal tunnel syndrome comes to mind. I have thought of purchasing a bunch from China as priced quiet reasonable now, $4-$12 ea, but cant get around the the CTS.
Basically wanting to make something similar and simple by using a battery operated metering pump or controller. The regular battery operated garden/ agricultural knapsack sprayers would be the perfect product but the pumps on these sprayers are high volume 1-2 lts/min and way too much pressure. Got thinking maybe a facet type fuel pump or something smaller with some sort of controller to cycle the pump to give the desired volume of liquid at the push of a button. A stepper motor on the pump with some sort of controller?
I have been chatting to some folks on Alibaba but they just want to sell me whatever pump they have got and don't grasp the idea of what I am looking for.
Another idea was some form of a peristaltic pump, but that seems too cumbersome and complicated to make.
Appreciate your input as always.
