I've got an Enerpac IPE5060 H frame press with a single phase PER-3042A 1.5hp electric 10,000psi pump and a 4 way 3 position tandem center solenoid valve. Very cheap auction buy with unknown history other than me having to replace the cylinder seals even before I ever had a chance to operate it under any real pressure- initially running it I could tell the seals were shot. Replaced the seals (enerpac cylinder seals seem to completely fall apart after a certain amount of time), flushed, and replaced fluid and it works, but the pump is loud when the cylinder is stationary and quiets down only a little when moving, also does not develop more than a few hundred psi. This style pump runs CONTINUOUSLY and just moves the cylinder when the up or down button is pressed, it does not run ONLY when you push the up or down button. I think someone was fooling with the valve at some point as the chrome locking nut on the valve block was loose (see photo). I believe the pump is two stage and only is generating 1st stage pressure- pump drawing: http://literature.enerpac.com/pdf/L1292_o.pdf and more at http://literature.enerpac.com/pdf/L2075_c.PDF with valve diagrams at http://literature.enerpac.com/pdf/L2079_f.PDF
I'm not sure if what I was able to find above is the exact manual. I'm making the assumption that the pump is turning the correct direction (and not sure that that matters- and the manual says check for correct rotation then doesn't even say which direction it should turn, and it should probably generate the same pressure in both directions as this pump is used for other double action applications besides presses) because a. its single phase and B. the cylinder goes down when I press the down button, and c. I didn't change any wiring- although I suppose its possible the hoses may have been switched at some point.
Before I take this pump apart are there any hydraulic experts who can suggest any adjustment that some boob might have made to screw things up trying to "fix" the pump/valve side when the real problem was the cylinder seals or if there is a common failure point on these pumps or valves? Is there a adjustment or failure mode that might result in the pump motor running against some pressure (without the pressure showing on the gauge) if for instance the valve was somehow partially actuated or something?
