Enlarging hole off center with end mill
Likes Likes:  0
Results 1 to 6 of 6
    Sep 2020
    Kentucky
    6
    Default Enlarging hole off center with end mill
    I want to enlarge a hole in steel off center. Would my best bet be to use an endmill and plunge?screen-shot-2021-04-09-10.03.25-am.jpg
    Feb 2007
    St. George, Utah
    1,295
    843
    878
    That will work fine. You can minimize wobble, if important, by using a solid carbide endmill and by not plunging too fast. If you need to meet tight tolerances you can also bore.
    Jul 2007
    Missoula Mt
    1,365
    58
    639
    Thats the way its done, use a very slow feed, if you can use a smaller endmill first, then the right size for the finish...Phil
    Jul 2006
    Hillsboro, New Hampshire
    13,040
    2946
    8956
    Quote Originally Posted by lmeuser View Post
    Yes, but to be clear, just on a mill with the tables locked (or CNC).
    Some newbs would try to use an endmill in a drill chuck on a drill press...
    Sep 2020
    Kentucky
    6
    Yes this will be done on my 3 axis. Thanks for all the replies.
    Mar 2013
    Danville Virginia
    205
    8
    94
    If it's on a 3 axis, then why not interpolate it with a smaller end mill?
