Expensive tractor tires dry rotting
Page 1 of 3 123 LastLast
Results 1 to 20 of 48
    Jan 2008
    New Jersey
    394
    84
    Default Expensive tractor tires dry rotting
    I've had to replace a couple large turf (wide) rear tractor tires recently at a cost of over $1k each because they develop small cracks/leaks around the "edge" where the sidewall meets the tread. Is there something I can do to prevent or delay this? They had plenty of tread left. These tractors are stored inside. I've been advised to spray them with "tire shine" but even those products' labels don't claim to prevent dry rot. Besides, if it has a picture of a corvette on the front of the bottle I'm pretty sure it's something that's formulated to just make the tire look wet and siphon money out of the pockets of idiots.
    I'm leaning towards spraying them periodically with biodegradable hydraulic oil (I have large quantities of that on hand). Anyone have any advise for me that's grounded in fact and not urban legend?
    -Roland
    Jan 2007
    Florida
    1,039
    122
    383
    a friend has had large cracks in his turf tires for more that 10 years. still uses it weekly
    Oct 2010
    Dewees Texas
    2,046
    25
    519
    I think petroleum based oils would be a bad thing, so hold off on that one. I am in the same boat with new tires on my big tractor and many going to pot on a center pivot, so I will be watching this thread.
    They used to have tire paints for park model mobile homes, not sure if they are still available or desirable.
    In the old service stations we had a rubber bushing lubricant to stop squeaking on the suspension, but I doubt that is a preservative.
  4. Likes Steven-Canada liked this post
    Jan 2012
    Midland, Texas
    1,431
    436
    722
    I have no idea, but I wonder if Fluid Film would help. It's lanolin-based.
    Jul 2006
    Hillsboro, New Hampshire
    5,755
    1365
    3986
    Stop the Rot: What You Need to Know About Tire Dry Rot - Evans Tire & Service Centers
    What you need to do is to clean the tires and apply tire dressing. I happen to prefer French tire dressing, but many people like the Italian version. But don't use Russian tire dressing, the rot will accelerate!
  7. Likes JRIowa, digger doug, JoeE. liked this post
  8. #6
    Aug 2012
    California, Central Coast
    2,406
    1999
    815
    The only thing that really works on tractors is Ranch dressing. Blu Cheese will make them mold faster.
  9. #7
    Jul 2004
    central NC
    2,487
    22
    604
    Quote Originally Posted by rmcphearson View Post
    I've had to replace a couple large turf (wide) rear tractor tires recently at a cost of over $1k each because they develop small cracks/leaks around the "edge" where the sidewall meets the tread. Is there something I can do to prevent or delay this? ..................
    Not really. From the moment the tire comes out of the mold the rubber starts to oxidize. You could build a big sealed box, park the tractor inside and fill the box with an inert gas to drive out all the oxygen but that may not be practical.
    In the future the folks around here just put a tube in it when it will no longer hold air. Not much can go wrong if you have a tire failure at 10 mph. Getting ready to pull a tire soon and take it to get a tube on my machine.
    I did have a leaking problem on the bead of one of the tires on my zero turn mower. Folks here told me about "bead sealer" which fixed the problem and I have wondered if when those don't hold air anymore if I can remove the tire, paint the inside with something like Berryman's and see if that works instead of a tube.
    Steve
  10. Likes TDegenhart, Mike C., art.h liked this post
  11. #8
    Sep 2002
    People's Republic
    2,454
    120
    1649
    Oxygen and sun cause it
    I am a fan of silicone grease
    While it may have some restorative properties* for rubber, i think it is mostly keeping the air away from it.
    IF a tractor is not going more than 10 mph I would not be all worried about some dry rot. My 1972 garden tractor has original front tires that leak some air and are drastically dry rotted, but I will run em till they can't do it anymore
    Now if it is a backhoe with street plates that can go 30 mph, that is a different story
    *1984 restored the rear suspension out of the 1970 sports car I still own. The little rubber plugs that cover the access holes for the rear struts were hard as a rock. Soaked them in silicone spray then grease. Became supple and 'as new'. Last I checked they were still in better state than 30 some odd years ago. Treated new suspension bushes similarly, and tho oil covered as were the original rotten ones, remain in good shape. YMMV
  12. Likes BobRenz liked this post
  13. #9
    Aug 2006
    Virginia
    568
    783
    335
    -Roland
    I can see your effort to protect your investment. That said ozone attacks rubber and contributes to dry rot. Stored inside with electric motors in the vicinity? May want to relocate if so. Had farmer relatives that had tractors with 50+ year old tires mounted and used with exposed cord patches on the sidewalls. They are tractors and not apt to cause lose control from a flat. I would only grease that squeak when I HAD to.
    Joe
  14. #10
    May 2002
    South Central PA
    13,142
    1947
    3149
    The story told about the invention of Armorall is that it was created to combat the effects of Los Angeles smog on automotive rubber body seals, don't know if today's product works the same. This is probably why you are told to use 'tire shine'.
    I have 50+ year old tires that still look good and 10 year old tires that are rotten so I think the formulation of the rubber is the biggest factor. I avoid Michelin tires for that reason, they are terrible for dry rot.
    +1 for the advice to run them until they fall off.
  15. Likes Greg White liked this post
  16. #11
    Apr 2004
    Modesto, CA USA
    6,321
    994
    Tire shops sell the idea of nitrogen fill for tires. no moisture entrained to cause wheel rust and I suppose it is inert so internal rubber rot would be reduced. I bet co2 would be similar.
    Bill D
  17. #12
    Aug 2010
    Minnesota
    1,622
    140
    1239
    Store it inside, about the only remedy I know of, that only goes so far though.
  18. #13
    Jan 2005
    Houston
    5,351
    438
    2224
    You didn't say why you had to replace them....were they unable to hold air, or did they just not look pretty anymore?
    If they still held air, let 'em crack all they want. If they leaked, and you didn't say how old they are, tell the maker they are defective.
    They still had plenty of tread left? Hmmm....I see lots of 50 year old tractor tires with plenty of tread left...it's not like they see a lot of high speeds and highways. It sounds like you are using your Corvette as a go-by in this situation.
  19. #14
    Jul 2004
    central NC
    2,487
    22
    604
    Quote Originally Posted by GregSY View Post
    Just for laughs, let me listen in on your phone call to Goodyear to complain that your 15 year old farm tires won't hold air any more.
    Tires get old, old enough and they leak air. On trailers or farm equipment the tread is normally fine when this happens. That's why they put date codes on tires.
    Steve
  20. #15
    Jan 2007
    Florida
    1,039
    122
    383
    i have a 84 yo customer that has about 50 restored massey ferguson tractors. last year i was over there and he was putting maybe the 25th patch on an original tube from an early 50's tractor that had the original tires - all cracked to hell
    must have been important to have all the original stuff
  21. #16
    Mar 2005
    Kansas
    7,116
    403
    3194
    Put a gallon of antifreeze inside the tire to stop leaks.
  22. #17
    Mar 2011
    Geneva Illinois USA
    5,480
    2207
    2075
    Just go with a tube until the tire falls apart. Only a few bucks for the tube, it gives up the ghost put in a new one.
    Tom
  23. #18
    Oct 2002
    Florida
    1,148
    120
    250
    My son is using a Massey-Fugerson tractor that I bought new in March, 1979. The nearly 40 year old rear tires look terrible from cracks, but they have most of the original tread and hold air. The front tires looked much worse and ceased to hold air a couple of years ago. Run those tires as long as they will hold air. The tire cord determines the strength of a tire.
  24. #19
    Dec 2012
    ny usa
    385
    244
    Who uses tires anymore? My girl runs the hover tractors while I supervise using a drone. (BTW G007 in drone speak means bring me another vodka and water)
  25. Likes fusker liked this post
  26. #20
    Jan 2005
    Houston
    5,351
    438
    2224
    "Just for laughs, let me listen in on your phone call to Goodyear to complain that your 15 year old farm tires won't hold air any more.
    Tires get old, old enough and they leak air. On trailers or farm equipment the tread is normally fine when this happens. That's why they put date codes on tires."
    Like I said, he didn't say how old they are. His post implies they are new...because who complains about old tires getting cracked? If they're new, therefore, he should complain about it to the maker.
    Tires get old and crack - but they don't automatically start leaking air. The OP is merely saying he had to replace them due to cracks...nowhere does he say those cracks leaked air or otherwise affected the performance of the tire. Read first, then post.
