jdelaney44
- Oct 31, 2021
Looking for any experiences and/or opinions about any of these:
I've seen a few posts here from a year or more ago from folks are using the GreenCut & the Hycut and are happy. Looking for updates or more recent posts if you don't mind.
Background - I have a CNC'd Bridgeport and will be converting a LeBlonde lathe to CNC in 2020 hopefully. Home / Garage shop setting. I use flood cooling & have devised ways to control splash & contain what does hit the floor. I've been using Trico TC1 which has been fine. I want to move to something as "non-toxic" as possible. I also use Accu-Lube LB-6000 in a squirt bottle when I don't want to fire up the flood system.
BTW, Ballistol might be in the running too.
-j
- LubeCorp's GreenCut Cutting Fluid (not the Plasma Arc Fluid).
- Oemeta's Hycut system
- Anything else that's at least claiming to not cause dermatitis & respiratory irritation
-j
