Explain Thread Micrometers to Me
Page 1 of 3 123 LastLast
Results 1 to 20 of 50
    Jan 2011
    Kansas
    736
    50
    58
    Default Explain Thread Micrometers to Me
    I'm looking at buying some thread micrometers as we have a whole bunch of threading to do. How do these work? I notice the Mitutoyo don't include anvils. There isn't much else to choose from except SPI and some cheap stuff on Ebay. Here is one
    SPECIAL NEW 0-1", 1-2" & 2-3"SCREW THREAD MICROMETER | eBay
    SHARS 1-2" Screw Thread Micrometer .0001" Graduation Anvil NEW | eBay
    Would you trust something like this? I need the anvils correct?
    Oct 2015
    AUSTRALIA
    71
    20
    I have no experience with those shars mics but you need anvils, and on these the standard is also important (the standard is not like a normal mic standard) you'll need a couple different sets of anvils to cover the range of pitches, same if you want to do Whitworth.
    I think you can check it on one set of anvils and then safely swap out (to Whitworth for instance) but I'm not totally sure
    Jan 2007
    Norfolk, UK
    19,043
    14547
    14651
    This should be good for another Gordon B Clarke fuelled bust up, …………………. and eventual banning of some poor sod.
    Jan 2002
    West Coast, USA
    7,732
    483
    5204
    As you may know, a single set of Mitutoyo anvils will work in all of their frames. Unlike the cheapies, they're nicely made. The anvils stay properly seated while still being free to rotate, the adjustments are precise, and so on.
    Once you get beyond 0-1" be sure each mic comes with the thread standard.
    You DO need to have the proper pair of anvils to cover the thread range being measured. Even then, the anvils on all these types are an approximation of the perfect thread form. Good enough for most work. Maybe not precise enough for some specs.
    What sizes do you need? I may have some extras in Mitutoyo or Brown & Sharpe etc.
  5. Likes adh2000, barbter liked this post
    Jan 2011
    Kansas
    736
    50
    58
    I actually was wanting to purchase 0-1, 1-2, and 2-3 thread micrometers. Let me know if you have anything you would like to sell.
    Dec 2019
    Wisconsin
    13
    I have Starrett thread micrometers that do not have interchangeable anvils. One is 8-13 tpi and the other is 14-20 tpi.
    Here is an example of one on ebay.
    Starrett No.575 Screw Thread Micrometer, V & U.S. St'd -8 to 13P With Case | eBay
    Mar 2009
    Brunswick Oh USA
    4,543
    5088
    2711
    I have a 0 to 6" set from Shar's. They have never let me down. Oh and a 6 to 7" Insize. If you buy used, make sure you get the complete anvil set and a standard. Most anvils cover a range of pitches. Choose the correct one and install them in the mic. Doesn't matter which way. Zero the mic with the standard placed between the anvils. You have to unlock the movable anvil holder and push it tight to the anvil when at zero. You'll get used to it soon enough. You are now ready to use them in the same way you'd use a regular mic. Keep the mic as close to parallel as possible. Check it by going one thread out both ways with just one anvil. The smallest reading is the one you want.
  9. Likes Red James liked this post
  10. #8
    Apr 2007
    West Virginia
    1,070
    551
    426
    I just bought a 0-1" Mitutoyo PANA mic (116-105), which as I understand it is the same as the thread mic but with a non rotating spindle. An advantage to the non rotating spindle is a variety of anvils can be used in addition to the thread measuring anvils. On ebay. My initial motivator is that I want to do some close measuring of some M3x0.5 threads. These can use the standard anvils from the thread micrometer or anvils that are not a point but more like a thread wire. I figured this would be a lot easier for the real small threads. The mic also came with a set of the standard anvils for measuring 24-14tpi threads. This was sort-of a wind fall because I thought I was buying a mic with no anvils. I wasn't sure if the standard thread anvils worked in the PANA mic but as I have found they do.
    I am in the middle of a job making some parts with 7/16-20 threads, single point on a cnc lathe, and have been using go-nogo gages. Man it is nice to be able to see where I am in the range. Thread wires are really great but I guess I am just not coordinated enough to use them efficiently. I am very impressed with the quality of this stuff.
    PETEM I think it was some of your posts that I was reading on the subject prior to taking the leap. Great stuff thanks! I don't think I would settle for the Chinese ones.
  11. #9
    Mar 2009
    Brunswick Oh USA
    4,543
    5088
    2711
    Here's an SPI 0 to 1" for $311 bucks.....without anvils. The Shar's is only $78 bucs....with anvils. Oh and they're the same damn thing!! Made by the same Chinese company. SPI makes NOTHING! They are what you call an importer.
    SPI Screw Thread Micrometer, 0-1" without Anvils - 13-514-5 - Penn Tool Co., Inc
    That set on e-bay the OP posted was $240. New they're $266
  12. Likes adh2000 liked this post
  13. #10
    May 2011
    New Jersey
    2,425
    213
    1305
    Quote Originally Posted by Limy Sami View Post
    This is in general not metrology, he can pound salt.
  14. #11
    Oct 2007
    SPAIN
    3,656
    2074
    1361
    For fear of wasting my time and getting my reply deleted because he who shouldn't be named doesn't like me but likes deleting my posts ...
    Mitutoyo digitals are the nutz
    I had a 0-1 & 1-2 and yes you have to buy anvils but you only need one pair as they fit both models.
    The 0-1 has no master setting rod as you zero it closed (@ zero).
    The 1-2 has a 1" setting piece.
    One thing to mention....we always made a nut too, just to ensure burrs weren't an issue or that the thread went right to the shoulder etc
  15. #12
    May 2019
    570
    146
    220
    Quote Originally Posted by plastikdreams View Post
    That's a piss poor attitude mister
    I have a moo goo gi pan one with interchangeable anvils. I was under $100. I do a fair amount of fairly fussy threading. I calibrate to known standards. Sometimes I make standards. I would trust a cheap thread mic with good standards over a fancy mic and a bolt.
  16. Likes ratbldr427 liked this post
  17. #13
    May 2011
    New Jersey
    2,425
    213
    1305
    Quote Originally Posted by Hardplates View Post
    Hah do I get strike 2?
  18. Likes barbter, Mcgyver liked this post
  19. #14
    May 2019
    570
    146
    220
    Nope, I just felt like says "piss poor attitude"
  20. #15
    Jan 2002
    West Coast, USA
    7,732
    483
    5204
    Quote Originally Posted by munruh View Post
    Munruh, Looks like what I have left are Swiss-made B&S/Tesa 0-1" and 1-2" with a complete set of US spec anvils (7 pair). Can send pix if you'd like. They're near mint condition and complete including the 1" thread standard. Closest Ebay comparable I could find (the 1-2" only, in fair and paint-marked condition) is this: NICE ! BROWN SHARPE SCREW THREAD MICROMETER 1 - 2 " .001 " | eBay
    One advantage of these is that the anvils are interchangeable with Mitutoyo. I suspect Tesa established the standard, and Mitutoyo followed.
    I'd sell the pair (0-1 and 1-2") for $425, plus whatever shipping and insurance you'd want. Same as the Ebay recently "sold" price for just one mic in lesser condition. Problem is, I don't have a 2-3". Also have a Mahr 0-1", beautiful thread mic, but only with two pairs of fine thread anvils and not as easy to find additions (but others may fit, see below). Somewhere I might have a 0-25mm Mahr with more anvils that can be used, but it seems to be hiding.
  21. #16
    Feb 2001
    Redwood City, CA USA
    5,004
    186
    924
    I have Mits 0-1 and 1-2 thread mics with most anvils. One thing I noticed with the 0-1 mic is that, if I zero the mic with the anvils touching and then measure a certified 1"-8 thread gauge, the reading is a few tenths off of the standard pitch diameter stated with the gauge. If I do the opposite, and set the mic to the gauge's marked PD, then they don't quite zero when closed. I suppose thread mics are a slight approximation compared to thread wires and comparators, but they are plenty good enough for any male thread turning or milling I do.
  22. #17
    Jan 2002
    West Coast, USA
    7,732
    483
    5204
    For what it's worth, years ago I compiled a list of thread mic anvil sizes; measuring those I had on hand. Turns out many follow the original Swiss pattern with anvil diameters to fit a 3.5mm hole. Others tend to use a 4mm fitting. The cheap Chinese ones tend to use a 5mm fitting:
    Anvil sizes
    B&S / Tesa 3.48-3.49
    China / Shars (straight cylinder) 5-
    Feinmess – Suhl, DDR 3.94 3.94
    Fowler (by?)
    Mahr 3.48 Split end, marked in scallop
    Mauser bench mic, mech digital 4-
    Mauser (0-25 & 25-50mm hand) 3.48 Length 13.5mm; Mitutoyo, Tesa too long – need ground
    Mitutoyo & Pana-mike, panamike 3.485-3.492
    NSK 50-75mm old set 3.52 Too large, marked on flats Nippon Seiko Kabushik Kaisha
    Nippon Seisoku 4 Old mic I had -- listed in COFES Micrometers
    PAV Liechtenstein (Swiss Economic Territory) 3.49 Perfect swap for Mitutoyo
    Toolmex (since distcontinued) 3.497 Fits Mitutoyo; grind in length to fit Mahr
    USSR 0-25mm 3.48 .137 & fit loosely in Mitutoyo
    VIS Poland 3.49 or so
  23. Likes Pete Deal liked this post
  24. #18
    May 2011
    New Jersey
    2,425
    213
    1305
    Hold out and get a well know brand, shars and shitty products inc. (spi) are bottom of the barrel brands. It's worth it in the end.
    Or you can just use some chinese digital calipers with cheesey attachments and a hokey pressure device on it...ahem
  25. Likes Cole2534, Pete Deal liked this post
  26. #19
    Nov 2003
    5,107
    180
    1606
    As long as the anvils used will come in contact with the thread at the pitch diameter, I see no reason why the zero would differ other than an inaccurate standard.
    Can anyone explain how that can happen? Dirty standard? Uneven wear on the anvils? What?
  27. #20
    Jan 2002
    West Coast, USA
    7,732
    483
    5204
    Quote Originally Posted by EPAIII View Post
    . . . Can anyone explain how that can happen? Dirty standard? Uneven wear on the anvils? What?
    One reason is that each anvil pair typically covers a range of threads. For Rich's 8tpi standard, the anvil might cover a range from 7 to 10 tpi. A perfect thread form has to be right at both the flank and the root. It's pretty easy over a range of, say, 7-10 tpi to see some differences in real world threads (and thread standards for that matter).
    All that said, thread mics are a terrific tool for most real world uses and unlike, say, thread wires (which should get the flank of a perfect 60 degree thread right) thread mics can be easily used with a part still in the lathe.
  28. Likes Eric M, vegard liked this post
