Extending a Milling Table?
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Jul 2020
    Hawaii
    5
    Default Extending a Milling Table?
    Hello, Is there a way to increase length of Travel on a Milling Machine? Can you extend a table?
    Langley, B.C.
    1,847
    406
    1078
    Short answer: No!
  3. Likes BT Fabrication liked this post
    Jul 2007
    UNITED KINGDOM
    5,333
    3259
    2729
    Longer answer: you can extend the table with a tooling plate, but the travel will remain just the same.
  5. Likes TeachMePlease liked this post
  6. #4
    Aug 2009
    Oakland, CA
    383
    179
    Midaco used to make a table extender that stacked on top of but it's been obsolete for years.
  7. #5
    Jul 2006
    Hillsboro, New Hampshire
    12,135
    2801
    8441
    Quote Originally Posted by TKassoc View Post
    But if you really needed more travel and couldn't get a new machine in, you could duplicate the functionality of the secondary slideway mounted to the top of a current table.
    Hell, you could drive it with a ballscrew and servo (or (shock!) stepper), using either extra M codes or even a contact switch for simple repositioning.
    A lotta work to do right, $$$ too, but possible.
  8. #6
    Jun 2003
    Mebane North Carolina USA
    6,892
    53
    2111
    A company in Ct built overlength table and screws for a bridgeport. Price was $$$$. I suspect you are talking about one of the unspeakable machines though.
  9. #7
    Jul 2006
    12,135
    2801
    8441
    Quote Originally Posted by Mebfab View Post
    Yeah, we don't know the OP's machine or needs, and HI isn't a hotbed of machining activity.
    I made a simple top plate that was keyed to the table of a VF-5, carried a set of contact plates and a rotary table to allow me to shift a plastic auger I was cutting so I could get the needed flight length.
    Greased the table to slide interface, the mill table was deep enough in Y to allow clamps front and rear to the slide plate for cutting loads. Worked pretty well...
    I did wind up with a slight step where the two sections of flight cutting met, but that was a little dum-dum on my part, not due to the method.
  10. #8
    Jul 2020
    Hawaii
    5
    Hello Friends, Thanks for the input. First time I've really used this Forum. But, I have put in my 10,000 hours running my old Bridgeport. Variable Speed J-Head. Dang I love that machine. But when I moved to Hawaii I did so with Suitcases. You guys are so lucky to be able to pick up a good milling machine at will on the Mainland. Over here I haven't seen one Bridgeport or anything for sale. In anycase, I make long Straight gunstocks for Spearguns, and I like to do the protyping and small productions on the Milling machine. (Yes.. it's wood. I know that will chafe some of you, but dang, show me a router that can whirl a big 1/2" Shank Woodcutting Router Bit at 5000RPM+ at the edge of the tool, Tapers in 2 dimensions, etc.. do alll that and then just flip a lever and slow it down and drill Hardened 17-4ph at less than 100rpm. 36" of Table travel was not ideal.. Guns are long, but now I'm looking at half of that with a machine I can ship here reasonably. (Take the good with the bad. I'm growing Bananas, it's 85 degrees and gorgeous, Ocean is incredibly gorgeous, kids are happy, wife is happy.)Is there Sled method? ie a table on a table?
  11. #9
    Nov 2019
    CANADA
    Ontario
    429
    615
    99
    only way is un clamp and slide and re indicate it in. or buy a big machine and ship it out there.
  12. #10
    Sep 2002
    People's Republic
    5,707
    682
    3581
    Bridgeport Milling Tool Hp-2 Head Mint - tools - by owner - sale
    hey it can be done
    [finding a mill in hawaii]
  13. #11
    Jun 2012
    Michigan
    13,113
    4452
    4735
    One can extend the travel and set the balance point to try to tip the table right off the base.
  14. #12
    Jun 2012
    Michigan
    13,113
    4452
    4735
    QT: [I make long Straight gunstocks for Spearguns,]
    Depends on your quality needs but one can fab-up a long trave to rig under a router head spindle..
    Just an I beam and a trolly can be hand ground to make a 60" travel .005 and better machine.
    A photo of your product might help the guys here give you some ideas.
    I would think a 2" diameter bamboo would make a decent long speargun handle/stock.
  15. #13
    Jul 2020
    Hawaii
    5
    hey it can be done
    Except that Joe is in California..
  16. #14
    Nov 2013
    Eastern Massachusetts, USA
    6,712
    5777
    6199
    Yes, you can extend the travel by making lead screw extensions and extended hand wheel brackets. Generally you can only safely get about 15-20% extra travel at each end but it depends on your miller's construction and how heavy a cut you take.
    It CAN be done but you need to remember the limitations when working at the extended travel and take lighter cuts.
  17. #15
    Feb 2011
    BFE Nevada/San Marcos Tx
    2,547
    2702
    1634
    hey it can be done
    There was a thread about that dealer here a few weeks ago, iirc he is one with a less than stellar reputation that has been discussed in many other threads.
  18. #16
    Sep 2002
    People's Republic
    5,707
    682
    3581
    Quote Originally Posted by behslayer View Post
    what?.............
  19. #17
    Mar 2005
    Kansas
    8,425
    568
    4190
    Yes. Don't do it as a motion table, but make it an index table. Rather than a tee slot table, use a piece of steel or aluminum as a fixture plate. Drill and tap wherever desired. However much additional travel you need, plus a little extra for that new project you haven't made yet. Lets say 10". Set up your aux table 5" left of center for one station, and index it 5" right of center for the other. Use keys that are a couple of thousands loose in the table to maintain alignment. You can make robust adjustable stops that position in the front tee slot, if your mill has one.
  20. #18
    Jun 2012
    Michigan
    13,113
    4452
    4735
    Adding a back rail like s surface grinder has can allow the part hilding fixture to be moved down the table
    So near doubling the effective length.
    A simple back rail is just using the T slots as locators.
  21. #19
    Sep 2002
    People's Republic
    5,707
    682
    3581
    Only time I had to do anything that exceeded the travel of my Lagun I drove dogs into the t slot and slid the plate down after doing a hole pattern, gage pin into the last hole in the first pattern and off you go.
    For repetitive work either a sub plate as mentioned or dogs and pins.
    After 15 years of owning my R2C3 I finally decided it was my machine, I could drill holes in it if I wanted to, and pinned my vises to the table
  22. Likes Oldwrench, TeachMePlease liked this post
  23. #20
    May 2009
    Wyoming
    3,612
    9013
    5863
    'Bout spit my coffee reading that. One of the biggest mental hurdles a shop owner will ever face, right there. But attitudinally liberating? You can't beat it.
  24. Likes TeachMePlease, gustafson liked this post
