Extending a Milling Table? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21
    Nov 2003
    5,774
    204
    1975
    It took you 15 years to realize that? Well, at least you finally did.
    If anybody objects to a non-factory hole in any of my machines after I no longer own them, I will send them a can of putty. From the grave if necessary. Case closed.
    Only time I had to do anything that exceeded the travel of my Lagun I drove dogs into the t slot and slid the plate down after doing a hole pattern, gage pin into the last hole in the first pattern and off you go.
    For repetitive work either a sub plate as mentioned or dogs and pins.
    After 15 years of owning my R2C3 I finally decided it was my machine, I could drill holes in it if I wanted to, and pinned my vises to the table
  2. #22
    Jul 2004
    Reddington, N.J., U.S.A.
    3,535
    470
    393
    Quote Originally Posted by dalmatiangirl61 View Post
    There was a thread about that dealer here a few weeks ago, iirc he is one with a less than stellar reputation that has been discussed in many other threads.
    He lists his machines in the New Jersey Craigslist as well. After a while you get tired of flagging them.
  3. #23
    Mar 2005
    Kansas
    8,426
    568
    4193
    Quote Originally Posted by EPAIII View Post
    Nope. Take out your letter stamps and mark it "oil". Tap and install pipe plug if desired.
  4. #24
    Oct 2017
    1,110
    334
    355
    A linear slide with a pneumatic cylinder to slide the other half of the table into the working area (with another to clamp) could be easy enough to implement into CNC controls.
