Face Mill recommendations for less rigid machine - Haas Mini Mill
Results 1 to 10 of 10
    Jan 2019
    ALAND ISLANDS
    38
    Default Face Mill recommendations for less rigid machine - Haas Mini Mill
    Looking to purchase into a quality facemill.
    1.5"-2.5" Diameter - insert that allows swapping for use in aluminum, steels, stainless, ti.
    Schools out for me on lead angle, I'd like ability for 90deg shoulders, however my primary goal is surface finish first and foremost. Mainly aluminum and stainless. Mrr at this time is not important to me as 99% of my work is prototype work.
    Buy once cry once... Where should I start looking first? Sandvik?
    Sent from my SM-G955U using Tapatalk
    Jul 2006
    Hillsboro, New Hampshire
    8,219
    1939
    5797
    2" Ripper mill: RIPPER MILLS Comes with inserts for Al, check with them about inserts for SS.
  3. Likes barbter, Limy Sami liked this post
    Sep 2010
    Oklahoma City, OK
    4,683
    804
    1924
    Another good option from the same vendor- 2 INCH ZCC FMA11
    Email or call them, explain your situation and I'm positive you'll land with a good result.
    Dec 2014
    CANADA
    British Columbia
    1,286
    361
    589
    We use a Mitsubishi AXD4000 in our non-ferrous applications in 1" and 2". Great finish and MRR. They have inserts for Al and Ti but they're not recommended for stainless.
    Jun 2006
    New Jersey
    3,099
    323
    279
    I have had very good results with shell mills from Mari Tool (Frank Mari is a member here) on a "less rigid" machine (Rockwell Horizontal/Vertical mill.) Mari makes the shells and also sells the inserts (Sumitomo, Kennametal, Corloy, Ceratip.) I doubt you will find a single insert that will work well for all your applications and materials. Also if you get one shell and have to swap out inserts every time you switch materials it will get old real fast. I would get at least two or three shells to start and set each one up with the best insert for the material and application. Talk to Frank Mari about your application (or your local tooling rep.)
    Mari Tool* is at Tool Holders, Collets and Machine Accessories - MariTool
    *Disclaimer: I am not associated with Mari Tool in any way other than being a very satisfied customer.
    -DU-
    Oct 2007
    SPAIN
    3,777
    2171
    1444
    + Another.
    I standardized on 40mm dia for the #30 Feelers and #40 Chevaliers i had.
    Jan 2007
    Norfolk, UK
    19,254
    14713
    14858
    That cutter is an absolute animal on Alu & Plastic, and with ''less than sturdy ''machines - stainless I can't help you with .
  9. #8
    May 2019
    Michigan
    125
    21
    31
    FOr steel and SS try a 45 deg. single sided insert facemill. I have an Iscar SOF845 with a double sided insert that cuts .315" deep. My VF-2 can't even get close to maxing it out.
  10. #9
    Jun 2012
    Michigan
    4,969
    4526
    2994
    Sandvik R390 has inserts for all types of material.
    Also if you're looking for strictly face milling their R245 is a great option.
  11. #10
    Jan 2019
    ALAND ISLANDS
    38
    Ripper mill, eh? Looks like a great roughing tool. Im assuming since it has been recommended here, it is capable of giving stellar finishes as well?
