Son of Sam
- Oct 11, 2014
- South Jersey, USA
I have a 3016 Fadal (bought used) that is leaking coolant (cutting fluid) in the center of the machine directly under the tower section/main casting. I traced the coolant lines from the pump up to the head and no signs of a leak in hose. I have also cleaned out under the way covers and any other place (such as the Y axis valley) that I have found grime. Machine was previously equipped with a pallet changer. All of the factory silicone sealing appears to be intact around where the casting meats the sheet metal. Currently running with pig mats and a mop bucket, loosing about 2 gallons on 8 hours. Someone please give me some indication of where to go next to fix this leak. Its driving me NUTZZZ
