Fanuc 10TF 10 TTL monitor honda connector Pinout - for CGA CRT to VGA LCD conversion
Results 1 to 8 of 8
    Dec 2014
    163
    17
    28
    Default Fanuc 10TF 10 TTL monitor honda connector Pinout - for CGA CRT to VGA LCD conversion
    Hi Everyone,
    I have an LCD display mounted and ready to go into an old shell of a Matsushita TX-1424AB CRT monitor from a Fanuc 10TF. PN A61L-0001-0074
    The Honda connector that goes to the monitor provides the RGB signal is the one I am interested in.
    I have searched high and low and cannot find a pinout!
    Can someone please provide me a pinout? I want to buy a scan converter to finish this project up.
    As soon as I do I will post the results.
    Thanks.
    Dec 2014
    163
    17
    28
    The closest thing I could find is this:
    The CN1 label is correct, but this is a 12" color CRT.
    would the signals wires be:
    VD01 = red ???
    VD02 = green ???
    VD03 = blue ???
    0V = Ground ???
    Here is a link to a good quality picture:
    https://i.imgur.com/mOYhSQE.png
    Attached Thumbnails Attached Thumbnails 2019-01-13-19_23_08-54815e.pdf.jpg   2019-01-13.jpg
    Dec 2014
    163
    17
    28
    Ok, I think I have found it. Can someone that has done this before just double check this:
    Makes sense, black wires are ground. V&H sync are the small connector and RGB and their grounds are the large connector.
    Will hook up to an arcade scan scaler board and post results in a few days.
  4. Likes RustySparks liked this post
    Dec 2014
    163
    17
    28
    It works! No scan doubler needed! The crazy LCD panel I have in there sync to everything.
    The pinouts found on the Fanuc maintenance manual for the 9" crt worked.
    I also found a post that verified the info. Here it is:
    D sub 15 vga -> honda 20 pinouts:
    vga honda
    1 -> 1 (RED)
    2 -> 4 (GREEN)
    3 -> 5 (BLUE)
    10+11 -> 8+9+10+11+12 (GROUND)
    13 -> 2 (Horizontal sync)
    14 -> 3 (Vertical sync)
    4,5,6,7,8,9,12,15 (vga not connected)
    6,7,13,14,15,16,17,18,19,20 (honda not connected)
    20.3KHz/55.25Hz FANUC control console timing
  6. Likes RustySparks liked this post
  7. #5
    Dec 2014
    163
    17
    28
    if you gutted your original CRT, here are the color wires attached to honda connector to pinouts on the VGA connector.
    VGA HONDA WIRECOLOR
    1 -> 1 (VDO 3) Red (RED SYNC)
    2 -> 4 (VDO 2) Yellow (GREEN SYNC)
    3 -> 5 (VDO 1) Blue (BLUE SYNC)
  8. Likes RustySparks liked this post
  9. #6
    Dec 2007
    Central Ohio USA
    3,941
    91
    1767
    Might be good to close out the (very informative) thread with the particulars of the panel itself. I don't have a need, but others might.
    Source, mfg numbers, price, basic size, link to manual/datasheet, etc...
    Same on your scaler board...
  10. Likes Billtodd liked this post
  11. #7
    Dec 2014
    163
    17
    28
    I hate it when I get to a post that has been solved but not closed out! Sorry!
    To find an LCD screen that would most likley work I searched:
    for "A61L-0001-0074 LCD"
    A few options came up in the $450 range.
    This seemed like the best plug and play option:
    Fanuc Replacement LCD Monitors- Matsushita TX 144 AB
    I have it installed in another machine, and it works great. It has what looks like a scalar board inside the case.
    Of course, I have more machines to fix so, I wanted something a little cheaper.
    I found a used CRT to LCD replacement from Omnivision On ebay.
    It was model number FP12B4G1-ZLn
    I have no idea what application it is for, it just looked like it was similar and would work.
    It did not have the additional board on the side.
    Perhaps I should have called and asked how much the universal option would have cost, this is essentialy what I got when I gutted the purchased monitor.
    Replacement LCD Monitors- 12.1" LCD to Retrofit 14" CRT
    Here are more pictures!
    219-1-14_Fanuc1T_LCD_Hack - Google Photos
    I also included some bushings I made up to more easily install the monitor.
    You just drill out the welded in bushings and then reinstall the monitor with slide in bushings. It made removing the monitor easy in my enclosure.
    I also took the cover off to show the LCD driver board. I could not figure out who makes it in order to source just the LCD.
    Hope this helps!
  12. Likes RustySparks, Chip Chester liked this post
  13. #8
    Dec 2014
    163
    17
    28
    one more thing:
    Prices:
    1,000
    Plug and play option. ready to roll. Ships same day.
    Probably the best option for most people:
    Fanuc Replacement LCD Monitors- Matsushita TX 14�4 AB
    $450
    Gut your crt, install new LCD:
    Search for "A61L-0001-0074 LCD" on eBay.
    There are a few options.
    Will add 2 hrs to install time. Not a bad option at all.
    Known to work.
    Best to have it in stock or replace your crt before failure.
    $300 - maybe less
    USED LCD - known to work.
    Search for used LCD replacements on eBay. I got the one above for $300.
    It was a for an early monochrome Mazak.
    $150 - the unpaved road.
    Find a 12.1" LCD direct from china that works. - I have failed to do this.
    8.4" replaces a 9" CRT
    10.4" replaces a 12" CRT
    12.1" replaces a 14" CRT
