mvernon
- Feb 10, 2019
- Pennsylvania
Hello all,
I have been working on repainting my Bridgeport mill body , knee. I cleaned all paint and bondo off. Then I primed with pro form epoxy. That seems to go well. After that hardened I proceeded to spray 3 coats of Evercoat featherfill G2 from a new can I just bought letting the coats flash off for about 10 minutes as the directions instruct you to do so. The problem is after 3 days I can still scrape the filler off with my finger nail. And it is to soft to sand with out clogging up then sand paper. I have used the proper amount of hardener and sprayed at 71 degrees with 60% humidity. Will this cure or do I need to sand off every bit and start over. Which I really wouldn't want to have to do. Please give me good news!
Thanks Matt.
Thanks Matt.
