eqshop9689
- Aug 31, 2017
Had a quick question. When you refer to what feed rate you are using, i.e. "running 30 thousandths feed rate" , which chart do you use on your lathes?
I have a 1957 lodge and Shipley and have three charts, leads per revolution, threads per inch, and feeds in thousandths. I am assuming I would use the feeds in thousandths, but what is the lathe doing if it's set at 30 thousandths feed rate (is that every revolution of the spindle it feeds 30 thousandths?).
I attached a picture of my charts.
Thanks Steve
Thanks Steve
