Feeds and Speeds for 1/8" Parabolic Drill - I keep breaking them
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    Oct 2019
    Idaho
    7
    Default Feeds and Speeds for 1/8" Parabolic Drill - I keep breaking them
    Hello,
    I hope someone can give me some advice.
    SPECS:
    Haas VF4-SS, 6061 Aluminum, Flood Cooling
    Chicago Latrobe 120DHT Parabolic drill, depth of 2.3 inches
    I bought a company that makes a product that has been in production for quite a while. I am a one man show at this point. Somewhere on the order of thousands of parts already made, 160 or so by me.
    We are drilling 8x holes per part at a depth of 2.3" deep, approximately. Accuracy only matters for the top 1" or so, and even then the tolerance is not all that important. We spot drill first and are using Chicago Latrobe 120DHT 1/8" parabolic end mills. Historically these have been drilled at 6112 RPM at 24IPM (200 SFM, .004 IPR) with a 0.75" peck drill. Since I have taken over the company (one man shop) I have cycled 160 or so units without changing out the bit, until recently when the installed bit broke. After the 1st breakI replaced it and the new one broke on the 1st hole. I replaced it again and got 5 holes out of it. Replaced again and broke on the 2nd hole. I have tried reducing my speeds and feeds to be as safe as possible with no luck.
    I have reduced my SFM to 150 which is 4584 RPM and and a IPR to .002 but still broke. I get a lot of squeaking on the plunge. Any ideas? Tired of making scraps! Those broken bits don't come out and my oops pile (wall of shame) is growing and more importantly I'm out of production at the moment.
    Thanks in advance!
    Alex
    Nov 2009
    Massachusetts
    306
    90
    Driving a 1/8" drill 2.3" deep will cause chip packing for sure:
    "Softer materials are best drilled with a deep hole parabolic (narrow lands, wide flutes for extra chip space) design. These drills are normally used to 14 diameters without peck drilling and are available with 118 or 135° split or notched points." This is from the 2013 Chicago-Latrobe catalog item for their parabolic drills, section titled "Deep Hole Drilling".
    14/8= 1.75"
    You need to peck at least once, and twice would be safer.
    If this is too slow, you'll need something like a coolant-through drill fed at high pressure, to force the chips to flow out, preventing packing.
    Jun 2015
    Minnesota
    244
    6
    81
    Check your runout at the tool tip. Make sure you have the exact replacement drill. If I recall, CL have a few types of parabolics with similar names.
    Mar 2005
    Northwest Indiana
    3,990
    680
    748
    Sounds like lower receiver woes... I agree, check and make sure you have the right drill. Then make sure you have correct coolant pressure. If the setup ran holes with no issues previously, something changed.
  5. Likes crane550, doug925 liked this post
    Jan 2015
    Missouri
    996
    210
    603
    I think your peck is to deep .75 sounds deep can you turn down the drill bit just past the tip to give the walls some room. I have a buddy who deep drills Aluminium he uses something called missle lube I don’t know what it is but he drills smaller holes then that deeper then that with missle lube
    Don
    Oct 2019
    Idaho
    7
    Quote Originally Posted by eKretz View Post
    The force is strong with this one! The first two I broke after the initial were the exact same. The only difference in the new ones are they are TiN coated. So far I have only broken one of the new ones...but only have tried to cut two parts. My last run was successful, I will post more soon.
    Jun 2015
    Minnesota
    244
    6
    81
    I would use bright over TIN in aluminum any day of the week, and weekends too.
    Dave
  9. Likes Dualkit, MattiJ, doug925 liked this post
  10. #8
    Oct 2019
    Idaho
    7
    Quote Originally Posted by D Nelson View Post
    Don
    This is what I am looking at next, the peck drilling.
    The last one I broke I was at S4500 F10 and a peck depth of .5in. Broke 1st hole.
    I put a new bit in and tried the following: (simplified)
    S6071 M3
    G83 Zx.xxx R-x.xxx Q0.125 F30
    Seems to work good, but I get a squeak around the 4th to 5th peck. Deeper it's quiet, and the first few pecks are quiet. But not breaking is good. Not breaking, no squeaks to make me nervous, and faster would be better.
    Read online about the 3-2-1 method, so I'm going to give that a try.
    Next cycle this is my strategy: (again, simplified)
    S6071 M3
    G83 Zx.xxx I.375 J.125 K.125 R-x.xxx F30
    3/8" peck the first time, 1/4" the next followed by .125" pecks.
  11. #9
    Oct 2019
    Idaho
    7
    Quote Originally Posted by 13engines View Post
    Dave
    Interesting, can you explain why? I am trying to learn this.
  12. #10
    Virginia
    26,767
    7561
    8375
    Quote Originally Posted by crane550 View Post
    It is trying to TELL you something, yah?
    Can't BOTH be right...
    Ain't running the Mother-f**ker in REVERSE or using wrong-rotation tooling perchance, are ye?
    Using CTD HSS-Cobalt parabolics "all manual" early 1940's Walker-Turner, since.. 1974 or so? Lovely drills. REALLY lovely.
    CAVEAT: Those were made in USA.
    Your "Chicago Latrobe" may or may not be.
    The Chinese owner is part of Dalian Top Eastern. Some of their factories are still in the USA, Chinese owned, US staff. Other factories are in China.. Europe.. etc..
    GFI | About Us
    Strange things are afoot with China, these days...
    It could be a dice-roll which source, and tip grind is crucial to chip-forming and everything else.
    Might want to look at Guhring, Triumph or such?
    BTW... Helical TWIST DRILLS, not plunge endmills. There IS a difference. Bigtime.
    My "peck" equivalent is almost never more than 1/4" in gummy shiney wood or steel, either one. Mainly 'coz I dislike shiny wood, treasure the drills and am a serious-cheap bastid.
    Do that - clearing 3 or 4 times as often - right away. The CNC high-speed idiot won't get tired, you'll buy yerself some leeway, and you may be back into production soonest, even if at a skosh longer cycle-time per hole.
    THEN see if your supplier has changed alloy or heat, fixture is moving, coolant has gotten crazy glue into it ...spindle has gone full of beach sand ...or just "WTF?"...
    .. 'coz SOMETHING has surely changed to make such an EXTREME difference.
    Totally off-the wall difference.. 160 units * 8 holes each = 1280 holes on ONE tool, suddenly down to one to five holes per tool?
    Not the same tip grind, not the same CNC code, not the same tool at all you THINK you had/have, first, chip-bind second, unwanted movement during the operation third are the highest on MY list.
  13. #11
    Dec 2018
    Arizona
    19
    13
    How's your coolant? You said you took over the business, did it sit for a long time? Is it fresh or old? Concentration? Different brand or type?
    Sent from my SM-N960U using Tapatalk
  14. #12
    Oct 2019
    Idaho
    7
    Quote Originally Posted by cb750chris View Post
    Changed it out two months ago. I have a refractometer, I will check it tonight and see where we are at with it.
  15. #13
    Oct 2019
    Idaho
    7
    You are also right! I misspoke, there is no end mill just a parabolic drill. It's late, too many hours working!
  16. #14
    Virginia
    26,767
    7561
    8375
    I picked up a trick ten years, watchmakers on staff. "Watchmakers" eye loupe. Simple creature. monocle with a clock-spring headband so both hands are free.
    Esslinger.com - Not Found
    Aim one of those at your drill tip grind. "8X" is a good sweet spot. Some other source should have them.
    Bad grind is obvious as sin when drills DON'T. (drill...)
    And we've MOSTLY skipped right past it off the back of TRUSTING what USED TO BE one of the several legendary-good American makers of drills.
    USED TO BE.
    The entire lot of we "expert" Chik'ns shall have to skip happy hour it turns out to be as dirt-simple as a bad tip-grind, yah?
    Get you at least a small packet of Guhrings. Clear-chip more often. Look to shave costs LATER.
  17. #15
    Jan 2005
    CANADA
    Saskatchewan
    10,222
    1392
    3674
    I'd likely end up peck drilling about 1/8" per peck with that small of a drill. I get this notion from peck drilling holes manually and that is about as far as you can go without chip packing (the squeak). Any coolant that went down the hole is gone well before you get done a 3/4" peck.
    The chip usually travels up a parabolic drill pretty fast, so it might be worth using one of the G73 high speed drilling cycles, and break the chip 2, 3 or 4 times before making the complete retraction to spin off the chips.
  18. #16
    Virginia
    26,767
    7561
    8375
    Quote Originally Posted by HuFlungDung View Post
    Aye. One Diameter seldom makes enemies...
    Surely CAN if ground "just so" off the back of it being formed into snakes coiled tight enough to not even touch the flutes or the walls. or at least they appear to not...
    But that's "Old Skewl", prolly no longer even remembered, let alone seen in a CNC world not into snakes nor bird's nests, either one, "flakes" rather...
  19. #17
    Apr 2005
    Beaverdam, Virginia
    7,347
    640
    3461
    I am lost here, maybe my coffee hasn't kicked in. I thought I read you had a drill run 160 parts, then it broke. Then all of a sudden the drills won't last so you start altering a program that previously made 160 parts on one drill?
    If the above is correct one of 3 things happened. The drill collet was damaged when the drill broke and now has excessive runout. The quality of your aluminum blanks you are running changed, like you were feeding it Kaiser and now you are feeding it Chinese junk 6061. The 3rd option is you aren't using the exact same type drill as before.
  20. Likes gustafson, eKretz, rpseguin liked this post
  21. #18
    Dec 2018
    Arizona
    19
    13
    Quote Originally Posted by Dualkit View Post
    That's why I questioned coolant as a variable that could have easily changed in what sounded like an already proven process. Although, as was said above by someone else, a .750" initial plunge is pretty deep for any coolant to be getting down in the hole especially with that small of a hole. Or it could just be a bad batch of drills like someone also mentioned. Maybe try the same style but from a different company? Seems like those things are more likely to have changed than anything else I can think of.
    Edit: I only saw the first paragraph of what I quoted, the second one wasn't there when i was typing. Also good possibilities there.
  22. #19
    Virginia
    26,767
    7561
    8375
    160 "parts" @ 8 holes each or 1280 HOLES on one drill, yet.
    That's not exactly a world-record, but still - the amortized cost, holes per drill buys the best drills in this class as are made with not a lot of strain, and is a right happy place to want to get BACK to.
  23. #20
    Apr 2005
    Beaverdam, Virginia
    7,347
    640
    3461
    I don't think coolant would become an issue that quickly unless someone just dumped a bunch of straight water in when the thing was low because of coolant getting dumped with the chips instead of evaporation. I do plenty of 25x diameter plus to deep drilling in 6061 in a pretty aggressive nature on a lathe and maintain coolant by sight and smell, rarely breaking drills. Although that is on a lathe. I do agree .750 on a first plunge is a little much, I think I would go .375.
