Feeds and Speeds for 1/8" Parabolic Drill - I keep breaking them - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21
    Sep 2002
    People's Republic
    3,337
    275
    2187
    Tell us the exact process, center drill etc
    Occurs to me that I have had problems with chips running up into the grooves in the collet packing the chips in the hole.
    IF you changed the drill and put it in the collet deeper[perhaps thinking better support] it could cause this
    Carefully setting the drill sot he flutes are not lined up with the collet grooves and that they end before the drill enters the collet.
    I have a dim memory of putting a 1/2 diameter disk on a drill on slower spindle machine to stop the chip loading in the collet or maybe chuck.
    I just looked it up, I run cobalt stub drills .121 dia, .5 deep[really .25-.4 material] no peck in 6063 at 10500rpm 120 ipm, and 5000 rpm 50 ipm, no center drill.
    I really don't know how many tens of thousands of holes I get out of a drill.
    Not apples to apples, but similar.
    A long drill I would center drill and run slower
  2. #22
    Dec 2008
    New York
    10,216
    2653
    Quote Originally Posted by crane550 View Post
    Hello,
    I hope someone can give me some advice.
    SPECS:
    Haas VF4-SS, 6061 Aluminum, Flood Cooling
    Chicago Latrobe 120DHT Parabolic drill, depth of 2.3 inches
    I bought a company that makes a product that has been in production for quite a while. I am a one man show at this point. Somewhere on the order of thousands of parts already made, 160 or so by me.
    We are drilling 8x holes per part at a depth of 2.3" deep, approximately. Accuracy only matters for the top 1" or so, and even then the tolerance is not all that important. We spot drill first and are using Chicago Latrobe 120DHT 1/8" parabolic end mills. Historically these have been drilled at 6112 RPM at 24IPM (200 SFM, .004 IPR) with a 0.75" peck drill. Since I have taken over the company (one man shop) I have cycled 160 or so units without changing out the bit, until recently when the installed bit broke. After the 1st breakI replaced it and the new one broke on the 1st hole. I replaced it again and got 5 holes out of it. Replaced again and broke on the 2nd hole. I have tried reducing my speeds and feeds to be as safe as possible with no luck.
    I have reduced my SFM to 150 which is 4584 RPM and and a IPR to .002 but still broke. I get a lot of squeaking on the plunge. Any ideas? Tired of making scraps! Those broken bits don't come out and my oops pile (wall of shame) is growing and more importantly I'm out of production at the moment.
    Thanks in advance!
    Alex
    1) obviously some aluminum is more abrasive (dulls drill faster) and sticks to cutting edges more easily especially if coolant not reaching drill tip. different material can easily effect things. if drill packed with chips coolant not reaching tip in a deep hole and drill tip gets hot chips start sticking
    2) chips sticking to flutes or still in hole. if rapids too fast coolant doesnt wash chips off drill and chips still in hole and drill rapid reentry crashing into chips still in hole can be hard on drill
    3) drill lot or sometimes whole package of drill bits is brittle and break extra easy. sometimes drill tip not sharpened correctly (slightly off) and is giving problems
    4) feeds and speeds. if sudden tool failure causing massive delays and extra costs often its faster and cheaper in the long run to back off feeds and speeds and peck depth and slow rapids. that is if going 50% slower is increasing reliability that often at end of year is the most important factor. like driving a car at 55mph rather than 100mph. might seem slower but avoiding a crash saves time in the long run
    5) if metal has hardness variations the drill will drift towards softer material. a curved hole and or wavy hole can be hard on some drill bits. some start resonance vibrating which can easily break drill bit. often vibration can occur even when feeds and speeds are considered normal. easily have seen that many hundreds of times. and often its not every hole could easily be 1 out of 10 holes where drill starts resonance vibration til it breaks. usually its a rpm drill doesnt like and often it needs a big rpm change to stop the vibration. tool length to dia ratio or stickout amount can have a big effect.
  3. #23
    Virginia
    27,630
    7561
    8603
    Thee yah go. Sub 2K holes per drill is no big deal.
    The drop to 1, 2, or 5 OTOH?
    That's like the fat lady who got too close to the train tracks.
    Dis-ASSED-her.
  4. #24
    Dec 2008
    New York
    10,216
    2653
    drill depth to dia ratio has a big effect.
    can drill a million shallow holes with no problems and can easily have massive sudden tool failure with deeper drill depths. you should try drilling .25 dia at over 12" depths with 24" long drill bit, its a lot different than 1" depths with a 4" long drill bit
  5. #25
    May 2017
    FINLAND
    1,775
    496
    812
    Interesting, can you explain why? I am trying to learn this.
    Aluminium sticks to (PVD) TIN coating more easily than bare metal.
    Aluminum Machining, Machining Aluminum, High Speed Machining | Radical Departures
    TiN: The titanium-nitride coating | RUKO
    "When machining aluminium only suitable with stationary machine tools using forced liquid cooling"
    PVD(physical vapor deposition) TIN coating is dull matt and slighly rough surface.
    Some drills also come with very shiny TIN coating and those seem to perform somewhat OK with aluminium.
  6. #26
    Mar 2005
    Northwest Indiana
    4,217
    845
    848
    He's doing lower receivers. That's one hole per workpiece. If the drill is the same and coolant is good I'd be looking awfully hard in the material's direction. Gummy aluminum is a right bastard to drill.
  7. #27
    May 2017
    FINLAND
    1,775
    496
    812
    Quote Originally Posted by eKretz View Post
    Same drill except the TIN coating..
    Material would be another good suspect even still.
  8. #28
    Virginia
    27,630
    7561
    8603
    "Drill" not-only..
    Have to admit so much so, my first reaction to facing that challenge is to see whether to make "whatever" in steel or bronze instead!
    A man has got to know his limitations. Lack of bleedin' PATIENCE on the list..
    Some OTHER Pilgrim deals with shiney-wood.
    Not as if there was only the ONE guy better at it than I care to bother to become, nor that folks get medals for doin' it. World is full of 'em. Their stuff mostly just works.
    Happy to JF buy the product of THEIR skills and experience, stick to the more predictable PITA-gnarlies like Mangalloys and Nickel-Aluminium-Bronze, thanks!
  9. #29
    Apr 2005
    Beaverdam, Virginia
    7,432
    698
    3510
    When stuck using crappy aluminum like Chinese 6061 or Service Center (Domestic reclaim, quality varies)I have found I have to up to triple cycle times over good domestic or European to keep from gumming up tools, breaking them and not getting a laminated finish.
  10. Likes eKretz liked this post
  11. #30
    Apr 2005
    Beaverdam, Virginia
    7,432
    698
    3510
    Quote Originally Posted by MattiJ View Post
    With drills and taps I use bright finish only on aluminum. They also are usually the cheapest to boot.
  12. Likes MattiJ liked this post
  13. #31
    Oct 2019
    Idaho
    7
    Thanks for the replies, everyone. We seem to be up and going again, although I watch that OP very carefully. If a bit breaks then you ruin a brand spankin new end mill...don't ask me how I know.
    I have changed to the following strategy and it seems to be working well:
    6070 RPM (200 f/min)
    30 IPM Feed (.0025 in/tooth)
    .375 first peck, .25 second, and .125 the rest.
    I think my issue was the peck depth. .750 was just way too much, even if it worked for a lot of holes. Might get more aggressive again in the future, we will see.
    Small squeak every once in a while but not bad. Also my coolant mixture was on the lean side so I added more. Pressure has always been good. Cut ~60 holes so far and no break. Still monitoring closely.
    Thanks a ton for the help.
  14. #32
    Virginia
    27,630
    7561
    8603
    Suggestion: Take out the first .375", start with .250", then to .125"
    Personally, I'd start with .125" and stay there.
    Either way, it's trivially more pecks, but your now-and-then squeak might cease?
  15. #33
    Sep 2002
    People's Republic
    3,337
    275
    2187
    Quote Originally Posted by DMF_TomB View Post
    I think we all understand the difficulty and difference drilling deep holes
    The example I gave while significantly shallower, was twice as fast, with inferior setup[no center drill], inferior tool[standard cylindrical drill] and gummier material[6063]
    I have done enough holes that I think he should be able to get near infinite tool life if set up correctly
  16. #34
    Sep 2008
    1,706
    1138
    985
    Maybe go as deep as you can with a short length cobalt drill, then switch to the parabolic, not too time consuming if you have an ATC.
    Something sounds wrong though, there's likely a simple explanation, why it worked well, then doesn't, I suspect the drill.
  17. #35
    Sep 2015
    Tennessee
    535
    257
    421
    Guhring 619 series, cobalt, uncoated, extra length 1/8" diameter, good for 20xD
    Quit using shit tools.
  18. #36
    Sep 2006
    Middletown, PA
    482
    160
    59
    .... Also my coolant mixture was on the lean side so I added more...
    How lean is lean?
    If this part ran with the original parameters, it would have needed alot of lubrication to keep the flutes from packing.
    Drill the same hole on a drill press to get an idea how much material has to come out per peck.
    None of my business, but have you had any machining experience?
