Are feeds/speeds for turning inserts typically on the back of the box?
Likes Likes:  0
Results 1 to 5 of 5
    Nov 2019
    Massachusetts
    15
    12
    Default Are feeds/speeds for turning inserts typically on the back of the box?
    Can't seem to find feed/speed info for most inserts on the manufacturers website aside from Sandvik but not always. I know some manufacturers give starting points for different materials on the back of the box, but do all/most as well?
    Mar 2005
    Indiana
    5,527
    1782
    1715
    Carboloy did also and still does I believe. Kennametal did not up until the point where I stopped being in the loop on them. Not sure on any others.
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    3,865
    71
    901
    speeds/feeds should be a starting point . they are not written in stone. certainly not on the box.
    i suppose they presume you're a machinist , and will have a clue what to do.
    situation, setup , ect ,other factors preside....HOWEVER...common sense should be a factor if "it ain't working" .
    Mar 2005
    Indiana
    5,527
    1782
    1715
    For some of the complex insert geometries they have a recommended range... It isn't like they say only run this particular feed or else. While I never paid them a whole lot of attention either, I can see how it might be nice on an unfamiliar material and/or insert geometry/coating to have a starting range.
    Jun 2011
    New Jersey
    1,345
    751
    564
    Some tool makers have all that online now. Kennametal uses the NOVO system.
    You can also check their print catalogs.
