Feeler gauge / thickness gauge
Likes Likes:  0
Results 1 to 5 of 5
    Sep 2007
    Australia
    Default Feeler gauge / thickness gauge
    Hi, I need to buy some metric feeler gauges to set the valve clearance on a motorcycle and have been told the width of the blades need to be narrow, around 8mm, I have searched the net but can't seem to find any that narrow. Could someone here set me in the right direction?
    Mar 2007
    wisconsin
    156
    212
    144
    Search for tapered feeler gauges. I have an old set made by A&E Mfg of Racine WI. They are about 6.5 mm wide at the tip.
    Oct 2010
    Oregon
    5,288
    4734
    1938
    Worst case, you can always cut or grind down the ends of a cheap standard width set, deburring like a fanatic so the edges of each leaf are no thicker than stock.
    May 2003
    Iowa
    10,490
    3616
    4281
    Dec 2008
    New York
    10,305
    2669
    Quote Originally Posted by daedong View Post
    i take some out of a 50 foot roll and cut with scissors. tapered end i cut too. usually bur is minor if worried about it could always sand it. can cut easily .005" with scissors
    usually 0.03mm or .0012" is only metric size i buy as rest i just use closest inch size
