I'm researching dust collectors for my shop. I work with a variety of materials, but mostly plastics, phenolic and steel.
I do some surface grinding of steels, but not a lot.
My biggest source of dust and debris is from plastics. I do many different operations with plastics which include cutting on a table saw, machining, welding, and even some grinding / deburring with a flex shaft grinder (done inside of a bead blasting cabinet).
I'm looking for a dust collector that can filter out very small particles. The cheap import type bag dust collectors are out of the question, unless someone makes a reasonable quality canister filter unit.
I'm looking more at two stage cyclones or the Torit type units.
Is it possible to use the same collector for the plastic and metal dust, or will I need separate units?
Is a two stage cyclone better, or the "baghouse" type Torit units that are very common?
Is there something else that I should be looking at?
Any input would be greatly appreciated!
btm
btm
