AARONT
Stainless
- Feb 19, 2013
- Madison, WI
We picked up an Epilog Fibermark 24 30 watt laser in the summer of 2018 and it had been doing great up until now. We only run it on average 1hour/ week. Recently we started having issues with the mark being faint and needing an extra pass or two to be acceptable. However it is now at the point that you can't see the mark no matter what we do.
I contacted Epilog and after the typical "did you change this setting, adjust the focus, clean the lenses, yada yada", they said the laser source is showing signs that it is failing and will need to be replaced. I asked what the life span should be and they replied "Lasers typically have a 3-5 year life span depending on use. But it is actually detrimental for lasers to sit dormant for long periods of time because the molecules in the laser sources tend to weaken."
I don't know much about the workings of lasers, but this sounds like some bs to me. Can anyone tell me if this is true or if they're just slinging some crap? If it is true, is there anyway to increase the life span without just randomly marking stuff every week?
Thanks!
Thanks!
