We are currently having a problem with metal shavings slipping through our filters and clogging up the coolant lines. Anyone have a Suggestion on the best type of filter to use?
I have had to deal with a similar problem with a fadal mill that was set up to cut carbon fiber the filter didn't work very well because the coolant lines from the tank to the filter would clog.
What did work was doubling the tank size and adding baffles.
If you just put a filter in it you will still have a clogging problem. It just will be before the filter.
Wow !
Can you be any more ambiguous ?
1. What "cnc machine" ?
2. What material ?
3. What coolant ?
4. What kind of sump/filter system presently ?
5. What have you tried already ?
Why didn't you post this in the "C.N.C. section " ?
It's been covered before, there.
Wow !
Can you any more ambiguous ?
2. What material ?
3. What coolant ?
