partsproduction
Titanium
- Aug 22, 2011
- Oregon coast
One of my 1440 lathes has developed a rattling noise in the headstock, more at some speeds than others but high RPM seems to make it worst. We took the cover off and inspected the teeth but they all look good, these are induction hardened and ground gears throughout As the RPM increases with no load the rattle comes in about 400 RPM (In high gear) and goes away as it gets nearer top speed of 1800 RPM, which makes me think it's an angular contact brg that's lost it's preload.
At any rate my assumption is that it is a bearing going out. Every bearing we could see from above looks good, no broken rollers or balls, but the big end bearing is hidden.
We tried to find where it was coming from using a stethoscope but with the cover off we have to pull it over by hand, lest it shower the shop for some distance with oil.
So, my question is this, is the only way to go forward to tear it apart or are there other methods so we can isolate the problem and not tear anything apart that doesn't need it?
parts
parts
