Finishing a small bore?
Results 1 to 12 of 12
    Jan 2011
    PA
    432
    137
    121
    Default Finishing a small bore?
    I got a part from a customer that has a 3/8" bore and he is looking to get a better than a reamer finish on the inside. I have tried those little abrasive brushes and they are ok but a little more work than I really want. I have some money to invest in tools so I was wondering if there is something in between an abrasive brush and roller burnisher that can be used in a CNC lathe.
    Dec 2012
    AUSTRALIA
    3,864
    18
    1352
    A Sunnen hone will get any finish or dimensional accuracy you need ,wont be anywhere as quick as a CNC machine tho......You may be able to use the CNC machine to push a stationary* ball burnish thru and back (non rotating.)
    Jan 2011
    PA
    432
    137
    121
    Sorry should have mentioned its a closed end hole
    Sep 2007
    Woodinville, WA
    1,839
    221
    409
    Flex hones. Many types available. BRM Flex-Hone(R), Industrial Brushes, Wire Brushes
    Mount the brush in a tool holder. Stroke with the carriage. Rpm as per the recommend for the size.
    Apr 2005
    Brandon, MS
    867
    129
    189
    Flex hone is a good, cost effective, suggestion.
    I'll throw out a roller burnish tool.
    Apr 2009
    Beaver County Alb. Canada
    1,924
    549
    947
    Roll-a-Finish | Burnishing Tools by Cogsdill
    WE used these at work , amazing finish is attainable,maybe 3/8 at bottom of hole will not be reached.
  7. Likes dalmatiangirl61, Illinoyance liked this post
    Jan 2007
    Norfolk, UK
    20,937
    16380
    16805
    I like these, simple accurate and cheap 2020 AcroLaps Barrel and Blind Hole Suggested Price List 3/8 under 10 bucks
    And the parts - like a 3/8 sleeve @ £3.65 2020 Acro Lap Barrel and Blind Hole Laps Suggested Replacement Price List
  9. Likes Pathogen liked this post
  10. #8
    Feb 2010
    ch
    2,931
    245
    399
    does the size of the hole matter?
  11. Likes BT Fabrication liked this post
  12. #9
    Oct 2005
    dexter mich
    314
    13
    80
    ball broach awesome finish fast look it up Ball Tech
  13. #10
    May 2009
    Canandaigua, NY, USA
    3,113
    156
    1472
    Not sure, but can a half round drill get a better finish than a reamer?
    Sharpenning hlaf-round drills?
  14. #11
    Jan 2007
    Norfolk, UK
    20,937
    16380
    16805
    Quote Originally Posted by Conrad Hoffman View Post
    Sometimes, but it depends on a lot of factors, .............with (IME) the biggest one being luck.
  15. #12
    Feb 2007
    Montana
    1,122
    12
    96
    Flexhone, but the hole is gonna get bigger.. as it will with any other method.
