First time machining internal threads on YAM lathe. What settings do I use? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21
    Sep 2006
    Stillwater, Oklahoma
    1,266
    87
    656
    Only a wild guess here, but I wonder if he's verified that the "b" gear is correctly meshed with the 120 T or the 127 T gear as required. It would be an easy thing to miss and might account for the 1.5/1.6 discrepancy.
  2. #22
    Jul 2004
    Houston, TX USA
    29,493
    Quote Originally Posted by TGTool View Post
    Great thought - thanks!
  3. #23
    Jul 2018
    13
    How do I do that?
    I haven't done a tune up on my machine in a long time. I am wondering if there is a taper being machined rather than a straight run. I started to think this because i don't think that 1.5 vs. 1.6mm difference in pitch would cause the fitment issue i am seeing with the two mating parts.
    Here is a picture just for fun:
  4. #24
    Jul 2004
    Houston, TX USA
    29,493
    How do I do that?
    Check and see if "b" is being driven by 127. For metric threads "b" has to be driven by 120
    Changing from one to the other will require the spacer next to "b" will have to change sides AND the 120/127 gear set will have to move closer to "b" for proper meshing of 120 and "b" AND the mounting (sometimes referred to as quadrant) for 120/127 will have to be swung up a little so the idler above 127 meshes properly with "a" - or possibly its just the 127 meshing properly with the idler
