greenbuggy
Stainless
- Oct 6, 2005
- Firestone, CO
Considering doing the epoxy thing to my semi-unfinished basement and garage floor to make it easier to clean and look a little nicer.
I'm sure I'm not the only one who has considered doing this, nor do I think I'm the only one with some imperfections in the floor I'd like to coat, so I'm curious for anyone who has -
Is there any preferred method of patching up the floor prior to laying epoxy over it? My basement has a few spots where some of what I'm guessing were redheads were driven into it and ripped up later, which took out much more than just a nail-sized spot, in some cases as much as an inch deep and couple inch wide "crater". A recent trip to one of the home improvement stores showed a kit from the same brands that were selling concrete floor epoxy sets for patching imperfections but it was expensive, IIRC almost $30 for less than a quart worth of patching material and I think I'd probably need a few hundred bucks worth of those kits in order to take care of all the spots I would like to be level before putting a coating over it.
So I'm curious, if you're going to end up coating with epoxy anyways, is there any reason to not blow the craters out with an air gun, mix up some quikrete and use that as patch material? Seems like most people shy away from that because of possibility of different color shade or slight texture/appearance difference. Do any additional precautions need to be taken to ensure adequate adhesion between the existing concrete and the patch material?
Beyond that, I'm sure there's people here who have coated floors many thousands of square feet more than I'll end up doing, but still curious - any more economical options than what the home improvement stores are offering? Seems like they're averaging about $120 for enough to do a light coat in a 1-stall garage and I'm guessing that somebody, either a local paint supplier or an internet purchase will have a lot more economical option if I'm buying a 5 gallon pail of the stuff rather than a bunch of small containers and redundant packaging.
