Fixturing Chank Hooks For Shank Turning and Threading
Likes Likes:  0
Results 1 to 9 of 9
    Jun 2012
    Davis Junction, Illinois
    157
    50
    26
    Default Fixturing Chain Hooks For Shank Turning and Threading
    Does anybody have a decent way to hold these? The last time I did one, I had a sketchy setup in a four jaw. The only regular surface on the whole thing is the part I need to machine.
    Tony
    Jun 2012
    157
    50
    26
    How do I fix the thread title so it says chain instead of chank? Ugh...
    Apr 2005
    Brandon, MS
    820
    117
    168
    Can you do it on a mill?
    Dec 2008
    minnesota
    159
    26
    161
    Once you get it center drilled so you can hold it with tailstock;
    they are not so bad.
    The bigger the four jaw, the better.
    We have done 20 ton hooks with 2-1/2" shank in the 21" four jaw
    on the 30" Le Blond.
    Mar 2005
    Kansas
    7,573
    438
    3493
    What is the shank size? I have done similar holding the shank in a drill chuck in the tailstock and bringing the jaws of the 4 jaw in one at a time until they just touch the part. The drill chuck may not work, it just makes it easier to center. Otherwise put in a center on a mill. Block behind the part so it can't slide. Then you can pinch the part between the chuck and tailstock so it won't fall out if you loosen the jaws to much when adjusting.
    Jan 2014
    Chicago
    153
    45
    53
    Ive never used a 2-jaw but i think think this is the type of lathe work they are good for. If this is for a larger quantity it might be worth looking into.
    Sent from my SM-G930P using Tapatalk
    Jun 2012
    157
    50
    26
    Quote Originally Posted by CatMan View Post
    Yes, I was considering an OD bore and threadmilling it. Still have to securely hold the hook end and get it aligned.
    Jun 2012
    157
    50
    26
    Quote Originally Posted by gbent View Post
    The shank is about 1.150"
    Feb 2017
    New York
    134
    10
    55
    Maybe make a fixture with a round OD to fit in a 3 jaw chuck that is profiled on the inside to the largest outside cross section of the hook part using the shank centerline (would be somewhat of an oval shape), cut a slit in the fixture so it clamps down on the part when you tighten the 3 jaw, depends on how many you have to do and if it's worth taking the time to make
