Due to limited space I'm planning to make a floating tap holder for the lathe. 3/8-16 max tap size.
The outside housing/shell will be built into the holder that bolts to the turret. Have some 4140 HT laying around to make it out of and some 1144 round stock to make the middle part.
Design is extension only and the normal slot, pin and spring design. Little fuzzy on the clearance needed between the two pieces. Figured .002" but not sure and also if a grease port is needed.
Any guidance would be welcomed.
