Fly Cutter Rough Surface Finish on Carbon Steel
Page 1 of 2 12 LastLast
Results 1 to 20 of 39
    Mar 2017
    Ohio
    9
    7
    Default Fly Cutter Rough Surface Finish on Carbon Steel
    I am having trouble obtaining a nice, smooth surface finish on carbon steel using an indexable fly cutter with my mill (pictures attached). The surface is very rough like sand paper and I can't figure out how to get a smooth finish. The fly cutter's cut diameter is 4in (2in radius) and I've tried running it at 600rpm starting with feeds from 2 Inches per minute up to 16 ipm, and then at 1300rpm with feeds from 6 ipm to 30 ipm and still no success. I tried depths of cuts from .002 to .010. I have been cutting with no lubrication and. I'm looking for what is causing this rough surface finish and how to possibly fix it.
    My observations are: I don't hear any chatter, I haven't seen any sparks, cutting insert is brand new and I don't see any signs of ware after use, my mill is sitting on 4x4's (vibration?).
    My machine's limits are 160-600rpm (low) and 1300-4600rpm (high) with feeds from 0-34 ipm in the x-axis only (all other axis's are manually adjusted). The mill is Kent USA KTM-5VK.
    I'd like to point out I am a novice in the machining world so I apologize if any of my terms seem odd. I am excited to learn as much as I can from you all and I appreciate all those who see this post and provide information. Also, can we please keep this discussion on this topic and avoid any unnecessary comments/off-topic discussions.
    Thanks!
    Cody
    Attached Thumbnails Attached Thumbnails img_0697.jpg   img_0696.jpg   img_0694.jpg   img_0695.jpg
    Feb 2011
    BFE Nevada/San Marcos Tx
    1,232
    1103
    668
    In the last pic it appears your feed is too fast, you might also consider reducing the stick-out of the tool in the flycutter. Have you tried using HSS, interupted cuts are hell on carbide. Is material steel, or cast iron? Swarf in pics looks like cast iron.
  3. Likes atomarc, cfoxx911, Ray Behner liked this post
    May 2009
    Canandaigua, NY, USA
    2,887
    141
    1290
    Agree tool is way out there. Remember if you try HSS you have to check SFPM and probably slow way down. If it's cast iron, dry may be OK, but if it's some sort of CRS or something, you need oil. I'd probably do it with a 3/4" end mill and live with the pattern you'd get. Or get that grinder you always wanted.
  5. Likes cfoxx911 liked this post
  6. #4
    May 2003
    Iowa
    10,492
    3616
    4273
    This is a first for me. I've never seen anybody use a turning tool in a fly cutter.
    JR
  7. Likes redlee, Matt_Maguire liked this post
  8. #5
    Apr 2007
    West Virginia
    1,047
    525
    415
    I have always used either brazed carbide tipped tools or hss, very sharp.
  9. Likes cfoxx911 liked this post
  10. #6
    Feb 2006
    Minneapolis
    208
    8
    27
    Hard to see but it looks like the cutting corner of your tool is quite worn. There's also a big exit burr which would indicate a dull tool.
  11. Likes Bobw liked this post
  12. #7
    Apr 2009
    Beaver County Alb. Canada
    1,856
    533
    906
    Try the same tool in a lathe with overhang the same and it will probably give the same results.3
  13. Likes JRIowa liked this post
  14. #8
    Jan 2008
    Mountains of Washington State, USA
    434
    135
    Fly cutter is way too small. Too much overhang with the tool. Wrong tool bit geometry. Feed to fast. Spindle RPM too fast.
    If you have much of this to do, buy a big fly cutter. Below, 3 inch A36 flat bar, the fly cutter is 3" in diameter. With a little tool projection the cut is made in one pass. I am using 3/8" HSS tool bits in the fly cutter. Note the cutting oil.
    dscn5713-1-.jpg2+
    For my operation in the photo:
    4 times the cutting speed divided by the diameter:
    A36 steel cutting speed is 100
    diameter of the tool about 3 1/2 inches say 4 for simplified calculations
    4 times 100 divide by 4 gives me about 100 RPM
    In addition to the 8 speeds in my mill I have a 3 hp DC motor on it with variable speed drive controller. I set the gearing/belts to approximate rpm and fine tune with the speed controller
    So I am saying your 1300 rpm is way too high.
  15. Likes digger doug, cfoxx911 liked this post
  16. #9
    Jan 2005
    CANADA
    Saskatchewan
    10,236
    1394
    3688
    No tip clearance for the cutting edge. It's a lathe toolholder, so it would appear, and the way you're using it would be equivalent to having the tool set about 1/4" above centerline: it's going to rub like crazy beneath the cutting edge, because that's where the maximum sweep of the tool is.
  17. #10
    Jan 2008
    434
    135
    Quote Originally Posted by Pete Deal View Post
    Yes Yes Yes. Tool bit grinding is the most important skill in a Machine Shop.
  18. #11
    Apr 2006
    Manchester, England
    8,369
    1234
    5319
    Quote Originally Posted by JRIowa View Post
    JR
    You've never lived JR ! I have but normally it's not a throw away tip tool.
    Regards Tyrone.
  19. Likes JRIowa liked this post
  20. #12
    May 2011
    New Jersey
    2,280
    201
    1249
    Head trammed? Really though who uses fly cutters anymore?
    Try running 300 ripems and an inch per minute. Copius quantities of cutting fluid of your choice brushed on the part.
  21. #13
    Sep 2017
    South Carolina
    475
    364
    394
    Lathe tool will not work in a fly cutter. Geometry is all wrong. Also, I can't really tell from picture, your slot in the cutter needs to be offset from the centerline by whatever size tool you are using, so your tool tip will be on the centerline of the cutter.
  22. #14
    Jun 2006
    Alabama
    1,883
    1089
    738
    A lathe toolholder/insert will work Great, but you have to make the fly cutter!
    I made one a few years back, it worked amazing facing hardened 4130.
  23. #15
    Mar 2009
    Eureka, CA
    3,772
    748
    1303
    Agree, a lathe tool fixtured properly will work fine..but that picture sure looks like cast iron to me, and cast iron doesn't finish exactly like regular old carbon steel. If your feed speed was lower the finish would look much better.
    Stuart
  24. #16
    Sep 2015
    441
    22
    186
    That definitely appears to be cast Iron, which will not require lubrication. Your tool is sticking out way too far, reduce the cutting diameter as much as you can. It is in the fly-cutter head backwards (you will also need the reverse of that tool holder style). That fly cutter is meant to turn the other direction. Cutting edge of insert should be about centerline of the tool. Lower your RPM to between 100-200 rpm and you should be able to get a decent finish at about 2-4 i.p.m. With anywhere from .01 to .04 depth of cut.
  25. #17
    Sep 2009
    Apex, NC
    1,489
    739
    Iscar F45E face mill or equivalent, 3" diameter or smaller. The feed, and speed can be higher, and it doesn't beat up the wimpy R8 spindle like a flycutter. Works well on steel to aluminum.
  26. #18
    Apr 2006
    Manchester, England
    8,369
    1234
    5319
    I had a little 4 insert positive rake throw away tip milling cutter about 1-1/2" in dia on the " Bridgeport " I worked on. I can't recall the make now but it was great. Did everything I wanted and didn't beat up the machine.
    Regards Tyrone.
  27. #19
    Mar 2012
    Geilenkirchen, Germany
    2,394
    1444
    1222
    As others have stated, your tool geometry is wrong. You are rubbing not cutting. Just like on a lathe, your cutting edge must reside on the center line. You need adequate back rake and cutting clearances. You have neither. I assume you have an R8 spindle, is so, you have questionable stiffness at that diameter, this is especially true and aggravated by that extreme hang out of the bit. If you must use indexable carbide, there are inserts designed specifically for this. The one you are using isn't. Can this be done on an R8 machine? Yes, but you should be using HSS. You need a larger, stiffer fly cutter, you need to go slower with lighter DOC and slower feed (watch your tool loading). Also, your head tram must be spot on or your result will not be flat. if your tram is correct, you will have a very fine cross hatch pattern as a finish. If you don't, it ain't flat. The tool's nose radius should equal 1.5 times the advance rate per revolution for the best finish. The greater the nose radius, the greater the tool loading and the greater the tool deflection. It is a delicate balance. In any case, it's good training. Just as others have stated, you are better off using an end mill and living with the tool marks.........the machine will be happier and the end result will be achieved faster and better.
  28. #20
    May 2003
    Iowa
    10,492
    3616
    4273
    Quote Originally Posted by Tyrone Shoelaces View Post
    You've never lived JR ! Regards Tyrone.
    Oh, I have lived. I have several flycutters that I use on very, very rare occasions. I learned many years ago how hard they are on BPs and that a good insert cutter will out perform them 99.9999% of the time.
    JR
  29. Likes Tyrone Shoelaces liked this post
