Winchesterguy
- Feb 27, 2021
I’ve been getting several calls (I guess a home shop local guy that did engine work has called it quits) about flywheel surfacing and some cylinder head work as well, curious if anyone here does engine machine work and could give me some info on RPM requirements for large fly cutters and grinding stones for flywheel resurfacing. I have a millport mill that I can use but I’ve read they’re not really rated for interrupted cuts on cast with large fly cutters, any advice on that would be greatly appreciated as well. I’ve actually gotten so many requests lately for this type of work I’m kicking around buying a larger K&T or Cincinnati mill (I’ve always wanted one anyways) and leaving my rotary table on the far end of the table and using the other end for cylinder head work. Any advice,tips or comments, good,bad or indifferent are welcome.
