Greetings everyone,
I was wondering if such a thing exists at all? A gas mask or a respirator that has a small electric powered air turbine or a fan that spins and helps force the air through the filter so that it is easier to breathe?
And then a microcontroller circuit board and a solenoid valve which would close upon exhaling?
You see, there is such a thing called respiratory acidosis and it cfan develop if you are breathing under a normal mask long enough, especially if you are physically active and demand more oxygen consumption.
Ideally, such a mask would contain 2 air turbines, 1 which would push the air through the filter upon inhaling and the other which would turn on upon exhaling clearing the carbon dioxide rich air out of the mask. Depending on whether the mask is solely for your protection or protection of others, a filter may or may not be needed on the exhaling turbine.
I know it sounds goofy but that mask would be a life saver for a lot of people who are in this situation forced to wear mask and are required to be physically active while doing so.
Perhaps it would be possible to construct such a mask?
The main question is whether such small air turbine (small rc electric ducted fan comes to mind, or even a turbocharger compressor) would provide enough pressure to push enough air through the filter to make breathing easier.
What are your thoughts on this?
