reimurray00
- Apr 11, 2019
I intend to learn about rebuilding a cylinder head. I have never rebuilt a head and there are things I will never understand without advice from someone who has rebuilt engines before. Also, my car is not a good beginning. It lacks popularity amongst builders and lacks industry support. Unfortunately for many engine specialists it’s also a common commuter car and so sadly they see them a lot.
I have a 2004 Dodge Stratus SXT with this engine -- Mitsubishi Sirius 4G64 SOHC 16V 2.4L 4 Cyl. 2,350cc. I have not removed the head from my car yet and it seems to work okay except I have had an engine oil sledge problem all around my engine just below the cylinder head. I plan to tackle numerous associated gaskets. However while I am at it I want to take out my cylinder head and if I have to replace it with a brand new head complete with internal components.
My main problem is with how I plan to remove and install the valve guides. Buying a new head should come with factory press in guides – this would solve the removal and install problem. But, I don’t own a shop (yet) and distributors usually don’t sell to non-wholesale buyers. I don’t know who sells a new bare aluminum head to retail customers.
If I can’t get a new head I have to remove guides. Choices are pounding them out with an air hammer and suitable removal tool or somehow drilling them out by hand. The old guides should be press in iron guides and the head is aluminum. Pounding the old guides should deform the guide bosses in the head. My factory service manual suggests using larger OD guides. But in the real world no one cares about selling guides of different sizes for some nameless engine. In my case should I pound them out?
What about drilling them out? Can I use some kit with valve seat alignment cones and hand drill?
What are core drill bits for? Are they ever used for removing guides?
This kit I am looking at is used with several valve seat alignment cones but comes with a reamer. If I am right I can’t use a reamer to remove the core of an old removable valve guide. How do I find a kit that uses the proper bit and cones? (Radiac Abrasives Carbide Boring Reamer Assembly #7389685 $120)
