CC
- Mar 14, 2006
- NW Pennsylvania
Good morning all
i'm looking for thoughts on tapping steel welded fabricated housings on a cnc mill.
We presently use spiral point taps (3/8" to 1") for threading holes in mostly a36 and some really hard a514.
We typically tap drill holes 1/64" over standard tap drill size. We typically tap the holes 2-3 tap diameters deep.
Some holes are blind and others are through. Tap breakage is minimal but happens regularly.
We rigid peck tap every hole, no matter what, retracting the tap completely out of the hole and then go back in.
The mills do not have coolant thru spindle, just a nozzle directed in the vicinity.
I'm just looking for comments regarding peck tapping vs in/out/done.....
Thanks for your time!
For what it's worth.....The main reason for the post is the enormous amount of wasted time going in and out and in and out....
