Form or cut tap for chasing tight threads in nickel plate brass?
Results 1 to 12 of 12
    Jul 2006
    rochester, ny
    2,395
    607
    786
    Default Form or cut tap for chasing tight threads in nickel plate brass?
    I use a lot of nickel plated brass hardware on my banjos, and often internal threads need to be chased because they are too tight. Threads range from 6-32 to 10-24. sometimes 8-26 (custom made taps)
    I've been using cutting taps, but wonder if I should be using forming taps? Seems the nickel should be tough on cutting edges. I really like the form taps for stuff I make, especially in blind holes.
    May 2021
    Virginia
    345
    374
    88
    I'd try a forming tap, since the threads are already cut in and you just need to "loosen them up".
    Sent by telegraph using - .- .--. .- - .- .-.. -.-
    Aug 2004
    Virginia
    2,966
    246
    1400
    Sometimes you can loosen up a thread that small by wrapping steel wool around the tap and going at it a few times.
    Jun 2012
    Michigan
    6,267
    5862
    4014
    If it were me, I'd use a cut tap to chase the threads.
  5. Likes MrWhoopee, doug8cat liked this post
    Jan 2014
    Temecula, Ca
    3,489
    1440
    4514
    if you're already having custom taps made, why not have them ground to an H5?
  7. Likes Winterfalke, BSCustoms liked this post
  8. #6
    Dec 2005
    Wisconsin
    2,018
    506
    692
    Short piece of threaded rod in a cordless drill plus some clover compound. Clean up is a pain.
  9. Likes 52 Ford, 1yesca liked this post
  10. #7
    May 2021
    Virginia
    345
    374
    88
    Quote Originally Posted by adh2000 View Post
    True. I used that technique on a big threaded hole in a welded part. Turned sorta oval shaped after welding. I needed it to turn smooth and didnt have a tap that large. Couple minutes with some aluminum oxide compound and a bolt and it's butter smooth.
  11. #8
    Jul 2006
    rochester, ny
    2,395
    607
    786
    Tbanks for the replies. These are parts sorta like fancy acorn nuts that I'm buying, not my tap that's causing trouble. Cut tap chases them just fine.
    If I start making these myself, I'd drill and form tap after plating. Better threads and no crap stuck in the blind holes.
  12. Likes 52 Ford liked this post
  13. #9
    May 2021
    Virginia
    345
    374
    88
    Quote Originally Posted by richard newman View Post
    Right. In something like brass, especially with an already cut tap, and especially especially in a bind hole, a form tap aughtta be quicker since you aren't making chips. Plus wear isn't much of a concern.
  14. #10
    Nov 2003
    6,146
    225
    2124
    Quote Originally Posted by 52 Ford View Post
    ...<SNIP>...
    - T
    .- A
    .--. P
    .- A
    - T
    .- A
    .-.. L
    -.-- Y
    .- A
    .--. P
    .- A
    - T
    .- A
    .-.. L
    -.- K
    In case any others were wondering.
  15. Likes 52 Ford liked this post
  16. #11
    May 2021
    Virginia
    345
    374
    88
    Quote Originally Posted by EPAIII View Post
    - T
    .- A
    .--. P
    .- A
    - T
    .- A
    .-.. L
    -.-- Y
    .- A
    .--. P
    .- A
    - T
    .- A
    .-.. L
    -.- K
    https://cdn.britannica.com/s:700x500...de-letters.jpg
    Attached Thumbnails Attached Thumbnails internationalandamericanmorsecode.jpg
  17. #12
    Jan 2007
    wales.uk
    1,911
    435
    454
    Use an oversize plating tap when tapping the hole, saves the effort of recapping
    Mark
  18. Likes BT Fabrication liked this post
