Vishwarath
- Mar 10, 2014
- New Delhi, India
We are in the process of form turning Aluminum tube on a lathe. The purpose is to reduce the end cross section of the tube from OD 12.5mm to dia 10mm for 30mm at one end. The tube thickness is 1.25mm through out. Drawing is attached. For this, the tool is placed just at the Bottom dead centre of w/p and progressively 'fed' transversely in three-four passes. We find some shape inconsistencies in this process. What should be the speed and nature of the tool to be used.?
