Forming or solder on barbs for 1/4" copper line?
Results 1 to 10 of 10
    Apr 2005
    Colorful Colorado
    963
    16
    50
    Default Forming or solder on barbs for 1/4" copper line?
    I'm fixing this ,shall we say thing, and I have a bunch of 1/4 copper lines that they just stuck some soft host on the end with
    a hose clamp.
    I'd like to add some barbs but I don't want to deal with the expense of a thousand swagelok to barb connectors.
    I've seen some little solder on barbs for 1/8 RC fuel line and I've think I've seen some formed ends on cars.
    I'd like to add something like that.
    Its just cooling water at maybe 20 psi, so nothing exotic.
    Was wondering if there is a simple, inexpensive and compact means to do this?
    Nov 2013
    Eastern Massachusetts, USA
    4,971
    4912
    4886
    Quote Originally Posted by Maxim View Post
    a hose clamp.
    I've soldered on some brass ferrules meant for compression fittings to do that. If you only need them on one end you can crimp them on with a compression fitting pair and then slide the fitting off the other end.
    McMaster sells the brass ferrules, as do many other places.
    Jan 2007
    Norfolk, UK
    19,307
    14771
    14921
    Apr 2005
    Colorful Colorado
    963
    16
    50
    Quote Originally Posted by Scottl View Post
    Why didn't I think of that? I only have a million of them laying around.
    Limeysam, yes like that but those are like $2 each on amazon
    Nov 2013
    4,971
    4912
    4886
    Earlier this year I paid $2.51 for a 10 pack of McMaster # 50915K613 for 1/4" tubing.
    Apr 2005
    Colorful Colorado
    963
    16
    50
    I meant, the parker ones
    Parker 238-4-4 Barbed x Solder Connector, Brass, 11/64 Barb Size, Brass - 1 Each: Bathtubs: Amazon.com: Industrial & Scientific
    Feb 2005
    9,130
    14473
    10915
    If you just want to make double triple quadruple sure the hose doesn't slide off,
    go get a cheap POS flare tool at the chinese orange store or AutoZone and flare
    the ends a tiny bit.
    Sep 2014
    Georgia
    374
    277
    141
  9. Likes Bobw, sfriedberg liked this post
  10. #9
    Jan 2012
    Midland, Texas
    1,523
    516
    784
    The Beading Tool is definitely the best way to go. However, if you happen to have a double flaring tool (used for making brake lines, etc.) you can might be able to use that and just stop after the first flaring step.
    How to use a Flaring Tool - Double Flare - YouTube
  11. Likes toolite liked this post
  12. #10
    Feb 2007
    St. George, Utah
    980
    520
    653
    Quote Originally Posted by Bobw View Post
    Actually, if you have a double-flaring tool just stop the first operation a bit early and you have a nice nub (with no sharp edges) to keep the clamped hose from sliding off. I use it quite a bit on copper and steel with pressures up to 120psi.
  13. Likes Mud, adama, sfriedberg liked this post
