JasonPAtkins
Hot Rolled
- Sep 30, 2010
- Guinea-Bissau, West Africa
Hi all!
My non-profit shop construction project in West Africa is on hold as I'm back in the U.S. to be with my wife's family because her mom is sick. I'm trying to finish up the drawings for the building so that when we're able to go back, we can hit the ground running.
While I was recently over there, I was able to scavenge some steel beams for the building which have opened up some new possibilities. I don't have enough to replace all of the building's reinforced concrete columns with steel, but I do have enough to replace a bunch of the central ones, enough to make it worth the effort to design to allow for a future bridge crane, I think.
Here's a render of the shop (13mb): https://drive.google.com/open?id=1yaF2UKLx1Dw-3kqoWzFsZvmcr69jmoPu
Basically, the large central area will be the sawing, forming, and fab area. The long room furthest away is the machining room. The red columns are the ones that I can now replace with steel. (The 9th one, that doesn't have an opposing twin, is just to get rid of that jib crane with one attached to the beam, just strong enough to hold a small mig welder).
Our normal method of construction would have each of those columns sitting on top of a 2' x 2' footing that's sunk about 2' deep. What I'm wondering is if I need to beef that up if those newly-steel columns were to support a 2 ton bridge crane. I have a very helpful installation doc from one of the crane companies which clearly lists the foundation requirements for each size of jib crane they sell, but I haven't been able to find such a document related to bridge cranes. The span is about 30' and the total travel of the bridge would also be about 30' (supported every ~10') in this scenario.
So, while I'm not asking for an engineering stamp from anyone here - I know you've all been around a lot of cranes. Do you know if any special foundation requirements are normal for a relatively-light-as-far-as-a-bridge-crane situation like this? Also, does anyone have any experience for what beam size would be used for the two stationary transverse beams, and for the single movable one?
As a side note, I'm also considering finding a few more shorter beams to replace ones on the outside wall of the machining room which would allow a second, shorter-spanned and lighter duty (maybe 1T) bridge in the machining room for moving heavy parts around. The problem is that the outer walls are only 10' and I'm afraid a bridge in there will be really low by the time it's all mounted.
Both of these cranes also have the unfortunate disadvantage that I don't have enough columns to extend them far enough to be able to park against a wall, so they'll be in the way, hanging significantly lower than the point of the roof trusses, in the middle of the room. But, they can be moved when needed.
