Four gear ratios for lathes and such
David_M
Hot Rolled
Sep 30, 2014
Midway, GA, USA
Hey, I have a piece of software that might be useful to someone out there. It does ratios using four gears :
It has a facsimile that shows the gear positions (May not be right for your needs???). It also lets you find gear combos that don't have multiple same size gears (use the >> buttons).
It is supposed to work on operating systems as old as windows xp, but I can't test that. It is 32bit by the way.
Let me know what you think good or especially if bad (I'll try to fix it).
Located here: Ratio4.exe - Google Drive
I made some big changes to it. Now, it has access to the gears being used so that unavailable and aggravating gears can be left out.
Checking and unchecking gears causes auto updates to the output.
If you get the above, choose 'More info' to get a 'Download anyway' or 'Run anyway' button.
