Free hobbing - a rogue method for spur gears
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 62
    Oct 2021
    ZIMBABWE
    Default Free hobbing - a rogue method for spur gears
    I am posting this thread topic to see if there is any interest in this obscure practice.
    The very mention of the subject seems to rattle cages and bring out some very thin skinned machinists like I was talking heresy
    To summarise
    Its a method of cutting gears without the complexity and cost of a manual dividing head and formed milling cutter or even worse a head geared to a mill spindle and using a hob cutter
    Let me say up front that I have the greatest respect for the science of gear technology and its practitioners. Its a very complex subject and has some highly skilled manufacturers who hold much of the expertise that is well beyond the home hobbyist
    What I propose for discussion and experimentation will in many ways tear up the rule book and start from scratch
    This method has been used to make wrom gears and this is a well documented procedure with ample vids on YT. I dont propose to elaborate on the area save to say that making spur gears is no more than an extension of the method (which has got some bad press in the past mainly IMHO due to faulty implementation of the technique)
    I have been experimenting in this area and have produced some encouraging results - even successes. I will offer to post pix and vids of my work and invite others to try the technique and report
    Up front
    This is a Cheap Charlie method that can knock out gears in minutes
    These gears - at this stage wont be to accepted DP/Mod standards (yet) but they will make quasi involute forms and can be assembled into a meshing train that seems to work
    At present the method only produces Mod 1(ish) 30PA pieces and is only suitable for light duty low power xmission on non ferrous mtls
    These might suit a model maker or experimentalist. The wheels are likely only to work amongst themselves but that may not be an issues - for example making a set of change gears for an old lathe
    I think the method can be extended to perform reliably to meet des criteria eg No of teeth, and predictable Pcd but it needs skill and experience
    I welcome the participation of open minded machinists but I wont be producing reams of explanatory words as the convolutions of the subject will be one big turn off, put a picture is worth...............
    and even better get your hands on when much will become clear
    for me very much work in hand and I believe there are others on this board who have been down this path
    Hope this doesnt start a forest fire
    Robin (no affiliation to Batman)
    Jan 2008
    Cary, NC
    295
    150
    81
    Hey Robin,
    I am quite familiar with the method to create worm wheels with, say, just a tap and perhaps a series of gnashes on the blank to get started.
    I can see how to extend this to spur gears theoretically. I am curious to see your approach and the results you have been getting so far.
    Jacques
    Sent from my SM-G998U1 using Tapatalk
  3. Likes Robint liked this post
    Oct 2021
    ZIMBABWE
    Default some pix
    Some of my earlier work, often paused waiting for parts
    An experiment with a single tooth cutter made from a 22mm spring washer
    I had ideas of making a variable pitch tool, but it would involve some tricky design and I needed to produce more tangible results to a skeptical host of viewers who said
    You cant do that its Against State Law
    so that is shelved just now - the tool only cost a few dollars and a few hours
    Note that the gear is slightly helical cos I didnt tilt the work piece ca 2 deg in the vice
    a tool made from M24 bolt. the slots are too wide and I am making a better on from bottom picm24gear.jpg
    OD 45mm
    Calc teeth 47 as predicted
    Pcd 43.7
    CP 2.91
    Mod 0.93
    DP 27.39
    I knocked out an aluminium gear to squash the naysayers
    More improvements due
    Robin Reliant
    ps note than in all cases the blank freely rotates on the mandrel, driven by the hob
    May 2021
    Virginia
    346
    374
    89
    Quote Originally Posted by Robint View Post
    Have you tried this with a DP or module worm?
    McMaster-Carr Page:
    McMaster-Carr
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Apr 2018
    9,782
    4699
    I wouldn't call it a rogue method, exactly … more like when you forget to clamp the parts down on the worktable.
    May 2021
    Virginia
    346
    374
    89
    Quote Originally Posted by EmanuelGoldstein View Post
    I think a rogue method would be holding the parts down with your hands while you make a cut.
    Dec 2008
    Vt USA
    9,677
    1743
    3572
    Sure would be hard to "build to print" .
  9. Likes barbter liked this post
  10. #8
    Jun 2013
    New York
    1,079
    733
    609
    Interestingly, I am also a stick shift. No automatics for me.
  11. Likes tdmidget liked this post
  12. #9
    Oct 2005
    22,780
    To summarise
    Up front
    First post and your lecturing ?
  13. Likes GregSY, neanderthal mach liked this post
  14. #10
    Oct 2021
    ZIMBABWE
    Q
    UQ
    Thats unfair and a snide comment - surely not worthy of your gravitas
    and I hope this is not going to be the flavour of how this board conducts itself
    My opening statement follows College convention in that the researcher sets out his pitch/aims/limitations and its supporting background
    I'll leave others to form their own opinions
    Please play nicely
    Robin
  15. Likes 52 Ford liked this post
  16. #11
    Feb 2007
    St. George, Utah
    1,488
    997
    1039
    There you go again, doug. Perhaps he grew up and was educated somewhere besides here. He is kind of a cocky bugger though. After watching the start at HSM I predict it will go south here before too long.
  17. Likes neanderthal mach liked this post
  18. #12
    Jun 2013
    New York
    1,079
    733
    609
    Quote Originally Posted by Gordon Heaton View Post
    By all means, check out the most recent posts/current discussion over there. I think the discussion here will be more interesting though. Especially if Zahnrad Kopf decides to participate.
  19. Likes Gordon Heaton, JST, neanderthal mach liked this post
  20. #13
    Jun 2002
    CANADA
    British Columbia
    3,317
    3324
    Hi Robint:
    The reason why you get pushback from all the professional machinists is because this is the most cumbersome way to get the crappiest gear shapes possible.
    If I have a gear to make I have lots of better options that will cost me less and produce a far better gear.
    I could:
    1) Buy a gear cutter and index a blank on the dividing head.
    2) Build a rack cutter and fake the Sunderland process with a rotary table.
    3) Wire EDM cut the gear
    4) Contract a gear maker and order what I need.
    5) Go to the Boston Gear catalogue and get the closest match.
    6 Build a little gear hobbing contraption for the lathe or mill.
    7) 3D print the gear in plastic or metal.
    8) Hand file the gear from a layout against a single tooth hardened template.
    9) Investment cast the gear from a pattern.
    And on and on.
    Although some of these methods will produce a pretty crappy gear too, none of them will be as awful as a free hobbed gear.
    If you wish to discuss just what makes them so awful, there is a long list, but you really need some basic gear knowledge for the conversation to mean anything to you.
    So this is a method attractive only to a beginner hobbyist who does not need to work to a high standard to make his project go, and can spend as much time as he wants fucking around to get not very much as a result.
    Yeah it sounds harsh, but that's the reality, so that's why the contemptuous pushback on this forum.
    Cheers
    Marcus
  21. #14
    Sep 2006
    Stillwater, Oklahoma
    1,939
    156
    1176
    OBTW I am not selling or pushing anything here - not a drop of snake oil in sight - just physically probing whats possible rather than armchair speculation
    I invite the adventurous manual machinists to join in this pursuit and share results
    Robin the brave
    Not entirely true. He's pushing the idea that he's the one to make a huge splash in gear production, one that no one else has done. The reward is lots of attaboys on the forums.
    I'd make just a couple points. First, that someone with their own shop and time can do anything they want. He's doing what he wants and that's great, but it doesn't require a salute from the industry.
    And second, from an industrial perspective, if it had enormous merit it would have already taken over. Why buy expensive machines and spend time chasing precision if you don't have to? Ideas and processes that provide an advantage take over. It's been than way from time immemorial. Spears take over from rocks, bows and arrows take over from spears, firearms take over from bows and arrows. Over time people recognize advantageous ideas and adopt them. And where has free hobbing been all this time?
  22. #15
    Jan 2005
    Houston
    7,326
    1426
    4324
    I think the point is...you show up with a hard-on from the moment you walk in the door. Are you looking for intercourse, or a fight?
    It looks to my eyes that you gears are Third World quality. Yes, they are gears but they look like gears that will work poorly and wear out fast.
    As for the 'stick shift' crowd...there seems to be an uprising taking place. A swelling of pride, if you will, amongst people who proclaim they can drive a stick! No automatics for them! They all share one common attribute that I can't help notice when I ride in a car with them....they suck at driving a stick. Yes, they are moving the car down the road so they are driving it....but their clutching sucks, they shift too soon or too late, and they suck at driving the rest of the car, too. I know about 3 people who can actually drive a car, stick or auto.
  23. Likes digger doug, pavt, Garwood liked this post
  24. #16
    Jun 2013
    New York
    1,079
    733
    609
    Quote Originally Posted by GregSY View Post
    and then there are those of us who grew up driving both semis and farm tractors, as well as cars and bikes. I still do the semis, being that I work in a semi repair shop. So, gears are kinda "interesting".
  25. #17
    Oct 2005
    22,780
    Quote Originally Posted by pavt View Post
    Double clutch, and some times, no clutch......
  26. Likes pavt liked this post
  27. #18
    Jun 2013
    New York
    1,079
    733
    609
    Most of the OTR drivers I know don't bother with the clutch. The 13 and 18 wheelers (Eaton gearboxes) arent' synchronized and it allows them to do it. My pickup uses the Aisin-Warner 5-speed, synchro, so there is no possibility to "float" the gears, you must use the clutch.
  28. #19
    Oct 2005
    22,780
    I had no problem-o with my Dodge 2500, you've got to match the speeds.
  29. #20
    May 2003
    Michigan
    3,102
    1789
    1558
    Fisher - Price makes better gears than this guy.
  30. Likes barbter liked this post
