Free State
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Free State
    Aug 2021
    Indiana
    5
    Default Free State
    What does it mean to machine material in a free state? When is it applicable? Materials? Is it a actual technique or something passed around as science?
    Thanks for excusing my ignorance.
    Sep 2006
    Stillwater, Oklahoma
    1,897
    152
    1126
    In my experience that means unstressed or unconstrained. That is, suppose you have4 a weldment set up for machining that might have irregular contacts with the table so that clamping warps it slightly. Machining is done and dimensions checked before unclamping. Everything looks good. Once removed from the clamping stresses and in its "free state" some dimensions may be off.
    Nov 2013
    Eastern Massachusetts, USA
    7,600
    6279
    6766
    Probably the closest to "free state" would be to mount the work with shellac "wax" or some kind of putty that hardens. This is often done for extremely irregular shapes that may vary slightly from piece to piece and would be extremely difficult to clamp.
    The piece gets "stuck" onto a mounting plate or mandrel for machining. Of course it then has to be "unstuck" without damage after machining.
    May 2021
    Virginia
    321
    351
    74
    Quote Originally Posted by Scottl View Post
    I hear it referred to as mounting wax.
    First result on the search engine. PELCO(R) Mounting Waxes
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Sep 2004
    south SF Bay area, California
    2,199
    239
    777
    Used a lot of zip-lock-type plastic bags partially filled with a "liquid shim" compound (plaster of Paris, anchoring cement, precision grout, or Hydrocal-type tooling plaster, or rarely, epoxy) mixed to a pea-soup-to-pancake- batter consistency to fill gaps between a casting or weldment and a temporary mounting surface.
    The polyethylene of the bag is compressible, but it was, to the best of my recollection, never a problem.
  6. Likes sfriedberg liked this post
    Virginia
    21,095
    7561
    12322
    Quote Originally Posted by Selvidge209 View Post
    Fair question , actually.
    "Non-distorting" clamping or fixturing, modest exposure I've had. Or "best efforts" that let you still DO something useful.
    Can't very well levitate the average item with NO constraints as if it were a hunk of rock in outer space, and the most stressful machine tool was nowt but a camera LOOKING at it, can one?
    FWIW-not-much, even a magnetic field or a beam of light impinges distorting force on an object. So does gravity, no matter how weak or distant.
    But if we are into Heisenberg's uncertainty principle?
    Best let Schrödinger's cat do the QC?
    Should get exactly a 50% pass/fail rate? Wouldn't be the first time 50% yield had to make-do?
    So "back to square ONE". Same as any OTHER tasking:
    Whom is going to DO the QA?
    What will they seek for acceptance?
    HOW will they measure for it?
    What are Plan A and Plan B to prevail?
    Basically belly-driven. Folk like to EAT reg'lar-like. No plan? No bid.
  8. Likes Selvidge209 liked this post
  9. #7
    Jun 2012
    Michigan
    14,248
    4855
    5137
    In grinding free state is holding the part with little or no clamping pressure so the part has no distortion.
    one example is the DedTrue surface grinder attachment. UNISON DedTru(R) Centerless Grinding Fixture | FlexMech Engineering It is not uncommon to grind the likes OD a small diameter reamer in its unfluted state to 2 microns with such an attachment / a feat almost unattainable with other methods.
    Another example might be gluing or just setting a part on the chuck or using little or no magnetism, but perhaps blocked in in the go directions.
    I used to grid round parts like dead perfect machine centers with them set on 4 bearings so to be like setting on/on a steady rest with only wheel pressure holding the part in place. yes with the but center or a point stop holding true to endways movement.
    Yes, the part must be stable in itself so its integrity does not distort in its structural being because a thin part or long part may distort from grinding wheel or cutting tool pressure.
  10. Likes Selvidge209 liked this post
  11. #8
    Apr 2018
    New York
    84
    39
    30
    Free state is a condition that a part sits in a fixture the same exact way that it would if you set the part on the table and haven't put any clamps or put it in a fixture with tension on it. Material doesn't matter. Ideally it is applicable with any part, but when I used to free state parts, they were large and had tight tolerances. I would either put the part in the vice or on an angle plate and run and indicator close to the clamps. The clamps would be just tight enough to put tension on the part, and when I got close to a clamp, I would loosen the clamp and watch the indicator. If it moved .005, I would place a .005 shim between the part and the plate. Double check that there was no indicator movement and go to the next clamp. This gets repeated with all clamps until there is no movement in the needle. It is a practiced skill and should be done each time the part is set up for a new process. It can be a pain in the nuts, or be a quick job. There is no predicting. If anyone would like to add or correct, feel free. I am a bit rusty at it.
  12. Likes michiganbuck, Selvidge209 liked this post
  13. #9
    Virginia
    21,095
    7561
    12322
    Quote Originally Posted by chuckg7442 View Post
    Concur.
    I'm prolly even rustier.
    I exercised the 'free state", early-on of not wanting to be bothered, went and did something else.
    Life was still full of pressures and distortions.
    But at least they weren't so damned PICKY nor unpredictable.
    And you even got to push back if you were on your game!
  14. Likes chuckg7442 liked this post
  15. #10
    Jan 2007
    wales.uk
    1,879
    425
    445
    I’ve come across cerromatrix used to hold for machining, low melt conforms without applying mechanical stress, was handy on the surface grinder too,
    Mark
  16. #11
    Virginia
    21,095
    7561
    12322
    Quote Originally Posted by boslab View Post
    Mark
    You left out highly recoverable and very nearly 100% re-usable, too.
    Much nicer to work with than "one time" plaster and faster than setting up poxy-putties.
  17. #12
    Aug 2005
    Toronto
    5,765
    3871
    4559
    Quote Originally Posted by John Garner View Post
    Used a lot of zip-lock-type plastic bags partially filled with a "liquid shim" compound (plaster of Paris, anchoring cement, precision grout, or Hydrocal-type tooling plaster, or rarely, epoxy)m.
    I just did this on the weekend to hold a small headstock casting in a mill vise so I could mill the bottom. I used bondo in a baggy, it worked well. The part gets scraped afterwards so wasn't super worried about the nth level of precision, but after setting and clamping up in the vise and carefully indicating the upside down bottom, it seemed work perfectly.
    Wax chuck work is common, or probably more correct to say was, in watchmaking work. Small stuff, where the pivot (think journal) on a shaft might be .004" tho. I've done it and its considered the most accurate way to get things spinning with perfect concentricity to an existing surface. The wax is really shellac. you melt a small bit on a 'wax chuck'. and put the part in the wax. To get the part aligned, with the lathe turning, you hold a flame under shellac and at the right temperatures it holds but is pliable. Then you bring something (using a rest) into contact with the work and every so carefully push the work into alignment. It takes a bit a practice to get the temps right, but imo is a neat process as perfect alignment is achieved with the simplest of tools.
    To remove the shellac afterwards? drop it in a test tube of alcohol and boil it over a flame....they come out perfectly clean
  18. #13
    May 2010
    Cambridge, MA
    1,866
    83
    1092
    That means you machine it in New Hampshire.
  19. #14
    Virginia
    21,095
    7561
    12322
    Quote Originally Posted by jscpm View Post
    But you would have a 50:50 chance of dying! They are unbaised bipolar!
    Or even BOTH?
    "Live free OR die" not "Live free XOR die" (XOR is 'exclusive OR')
    Preston County West Virginia, AKA "the Free State of Preston" is where you wanna bee!
  20. Likes 52 Ford liked this post
  21. #15
    May 2021
    Virginia
    321
    351
    74
    Or even BOTH?
    Thought that Houston was supposed to be the free state.
  22. #16
    Mar 2009
    6,433
    126
    1249
    To machine a material in deep state. The shop has to be underground with no windows, no natural light.
    The building must be surrounded by a fence with concertina wire on top. One more thing. The boss did
    not interview for his job position. He was appointed by a bunch of rich globalists.
  23. #17
    May 2021
    Virginia
    321
    351
    74
    Quote Originally Posted by rons View Post
    FREE state. Not DEEP state. Wayyyy different parts they make.
  24. Likes Winterfalke liked this post
  25. #18
    Jul 2006
    Hillsboro, New Hampshire
    14,151
    3095
    9383
    Little surprised that Don didn't kill the thread due to the meaningless tittle. Glad he didn't, there's some good info here.
  26. #19
    Oct 2007
    SPAIN
    5,364
    1193
    659
    I've never come across a drawing stating "machine in a free state".
    But a few that state "Inspect in a free state"....which is the important thing....in reality?
  27. #20
    Apr 2018
    New York
    84
    39
    30
    Quote Originally Posted by barbter View Post
    In reality it is implied by the print, for example getting a 6 foot aluminum plate to stay within +/- .01 of an inch with several 2 foot holes milled out of it. What fun I used to have at work.
