Hello
I need to design a hinge that requires 5-20 Ft/Lbs to rotate, is smooth to operate, and has a luxurious tactile feel to it. The hinge simply holds a touch screen in place on a machine in the medical industry.
The tension will be adjustable by means of a screw pulling together a split ring.
My question is what material should it be made from? I would assume some kind of plastic?
