fun acme thread job
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
    Dec 2008
    phoenix, az. usa
    83
    100
    Default fun acme thread job
    Got to run this threading job recently. 20" diameter, 1" pitch, full root radius acme thread.
    came out pretty nice when they were done.
  2. Likes Bobw, eKretz, Ray Behner, jmp, michiganbuck and 16 others liked this post
  3. #2
    May 2009
    Canandaigua, NY, USA
    3,239
    161
    1570
    Wow! 3-wire measurement on the size?
    Aug 2008
    Californeeeah
    1,566
    58
    351
    Did you check it with thread wires?
    May 2005
    Republic of Arizonia
    1,808
    565
    Excellent, What is the part for?
    Dec 2008
    phoenix, az. usa
    83
    100
    I did indeed have a (one wire) size to hit.
    (Is it really a ‘wire’ when it’s a .500” gauge pin?)
    Anyway, we also do an actual fit test (I made the nut, as well.
    If customer requires it, we can do a Faro arm/Romier arm quality control document.
    Fun stuff. I’ll post a pic of the nut in a bit.
  7. Likes lumley32 liked this post
  8. #6
    Dec 2008
    phoenix, az. usa
    83
    100
  9. #7
    Dec 2008
    phoenix, az. usa
    83
    100
    It’s for a mining shovel.
  10. Likes DrHook liked this post
  11. #8
    Dec 2008
    phoenix, az. usa
    83
    100
    unrelated to threads above, but here's a pic of my co-worker who is currently loading this ring (~50,000 lbs) into the VTL.
    It will become a large ring gear soon.
  12. #9
    Jun 2004
    612
    498
    109
    dam and i was thinking it was the beginning of a breech plug for a cannon tell i seen the other pic. with them threads at the end of that long shaft
  13. #10
    Mar 2021
    CANADA
    Ontario
    All I can say is very impressive!
  14. Likes kustomizer liked this post
  15. #11
    Jan 2007
    wales.uk
    1,713
    348
    385
    You really don’t want to muck up jobs that big, what’s the slew ring off?
    Mark
  16. Likes pavt liked this post
  17. #12
    Dec 2008
    phoenix, az. usa
    83
    100
    Quote Originally Posted by boslab View Post
    Mark
    It’s the gear that rotates the “house” on the dragline. When the dragline scoops the dirt, this gear rotates it to the dumping position, then back to scoop more.
  18. #13
    Mar 2005
    Kansas
    8,564
    590
    4308
    Was the gear blank rolled or forged?
  19. #14
    Jun 2013
    New York
    901
    609
    479
    Mark
    Ja, there are times when one is not allowed to say "Oops". This is one of them. No pressure at all, nosiree bub. Says the guy that used to weld pipelines in a chemical plant. I do hope you all are being fairly compensated for these "hi-pressure" jobs.
  20. #15
    Dec 2008
    phoenix, az. usa
    83
    100
    Quote Originally Posted by gbent View Post
    It was forged.
  21. #16
    Dec 2008
    phoenix, az. usa
    83
    100
    Here's a pic of it on the angle plate getting hole pattern.
    co-worker in bottom of pic for scale
  22. Likes ratbldr427, bosleyjr liked this post
  23. #17
    Jun 2002
    CANADA
    British Columbia
    3,107
    2900
    Hi scottwhisler:
    Where did you get such tiny fingers for the photograph in post #1?
    I ask because I get asked every once in a while where I got such BIG fingers for some of the pictures I post.
    All joking aside...nice job; it looks good!
    Cheers
    Marcus
  24. #18
    Jun 2012
    Michigan
    5,896
    5567
    3757
    Normally when someone here talks about a large part, there's many of us that would consider their part to be small.
    I don't believe this is the case with your parts. That's friggin huge!
  25. #19
    May 2009
    New Jersey
    337
    88
    58
    Quote Originally Posted by scottwhisler View Post
    Great work, really impressive...
  26. #20
    May 2007
    Massachusetts
    1,474
    534
    1277
    That is amazing work, I would love to see the machine you made it on and the tool you cut the tread with.
    We do 80% turning here most of our parts have threads, 9.00 round is considered a big part in this shop. I just showed this to the guys who are working today and they were all impressed.
    I am sure you are a valued member of the team.
    Make Chips Boys !
    Ron
