Terry Keeley
Titanium
- Oct 18, 2005
- Toronto, Canada eh!
I see 6Al4V is OK to laser weld but can small gaps be bridged? I have a part with a hole drilled in it that broke through the surface, tried JB weld but it didn't hold.
Tried various methods on some race car stuff, the only one that really worked was done in a vacuum.In addition, specifically for titanium and its alloys, the exclusion of oxygen from the weld zone is critically important, so your argon coverage has to be very good, and cover both sides of the weld.
Good morning Terry Keeley:
I laser weld a lot of titanium in my shop, and here's what I've found.
First thing to know is that there are two kinds of laser welders out there...the most common uses a burst of energy repeated very quickly and makes discrete spots that you overlap to make your weld.
The second is "continuous wave", which functions exactly like the name implies and works much like a TIG torch
Moving on to your question...it depends on what you are calling a "small" gap
I try to aim for a very good joint fitup...0.001" gap or better.
The reason is that with my pulsed machine, the pulse duration is so short (milliseconds) if I have a significant gap, the puddle never has time to coalesce into one and I get two melt puddles, one on either side of the joint gap.
Continuous wave lasers don't do this...there is no pulse, so the beam is on all the time and you can hit the same spot for long enough to let the metal flow into one melt pool, and then just feed in filler wire...just like with TIG.
As you can imagine, with a beam diameter that only goes up to 0.020" wide, any kind of significant hole is a nightmare to plug weld with a pulsed laser of the kind that are sold for jewelery making and dental lab work and fine assembly like medical devices.
You have to use filler wire to fill a gap, and for me a telephone-pole sized wire is 0.015" diameter.
The blob it will deposit from a single laser pulse is maybe 0.007" tall and 0.020" wide.
So a scar 10 mm long and 2 mm wide takes hours to bridge with filler wire alone.
That means a properly shaped patch to do it in any reasonable amount of time, and the patch has to fit super well, so it's not trivial to make.
That means some sort of back purging setup which you also have to make and mount to the job, and plumb for argon.
As you can see, this is all getting very complicated, and makes laser welding look less and less attractive compared to TIG.
Cheers
Marcus
Notice
