Garroting a tree.would it be possible?
Page 1 of 3 123 LastLast
Results 1 to 20 of 56
    Oct 2013
    st,louis mo
    784
    396
    Default Garroting a tree.would it be possible?
    If you could make some piano wire out of the highest tensile strength material,could you wrap it around a tree to slice it down? Edwin Dirnbeck
    Mar 2005
    Kansas
    8,797
    632
    4523
    No. Try it with a 2x4 first.
  3. Likes digger doug, 1yesca liked this post
    Oct 2005
    22,784
    Quote Originally Posted by gbent View Post
    That's a vendetta that spans qty (2) generations.....
    Too Much Chicken - YouTube
    Jun 2006
    Spokane, WA
    769
    6
    231
    Yes, in theory, if the wire were of infinite tensile strength, it could be tightened enough to overcome the cellular bonding of the tree. But in practice, no.
    Does anyone here remember the flexible pull saw?
    jack vines
    Jul 2019
    Connecticut
    40
    83
    13
    Id imagine the tensile strength needed to garrote a tree would require some pretty thick wire. the thicker the wire, the harder for it to "slice" thru. it would end up either being too thick to wrap around a tree or the wire would have too much surface area to cut thru the tree and would squeeze the tree until the tree wont compress anymore and break the wire.
    Nov 2013
    Eastern Massachusetts, USA
    7,820
    6494
    6918
    Yes, if it were done in a manner similar to how stones have been cut using spooled wire that is continuously pulled through the cut. For stones they use an abrasive slurry along with the wire. Bare wire could be used for a tree but it would eventually char the cut and maybe even set the tree on fire.
    But why?
    People have successfully used everything from 2-man saws to grapple mounted chainsaws to cut trees. Years ago I even read of a technique where a plunge cut was made into the trunk and a bag inserted and then filled with a 2 part liquid explosive that would "slice" through the trunk on detonation. apparently it was meant for military uses such as quickly clearing trees and also for things like cutting firebreaks in a hurry.
    IMO pulling a wire through a trunk would be the most inefficient method other than trying to do the job with a serrated steak knife.
    "If God meant us to work that hard he wouldn't have invented power tools"
  8. Likes JohnEvans, Sparky45 liked this post
  9. #7
    Jul 2013
    atlanta, ga
    379
    38
    303
    Quote Originally Posted by Scottl View Post
    I don’t know why they would bother with binary explosives for that application, when we’ve had primercord capable of doing the same job for quite some time.
    Primercord and the PETN explosive within are *VERY* fast acting (21k/sec.). As long as the primercord doesn’t “cut” itself it will cut through all manner of materials like driveshafts, bridge supports and tank treads… even the densest tree isn’t gonna give up too much resistance, provided some effort is made to direct the explosive for inward.
    I’ve used it in motion picture work to cut limbs off for aerial-burst explosions. Two wraps of 100-grain primercord will separate a 6” limb from a tree posthaste.
    Jeremy
  10. Likes 1yesca, 52 Ford, MetalCarnage liked this post
  11. #8
    Oct 2005
    22,784
    Steep Slope Harvesting in Chile - YouTube
  12. #9
    Feb 2006
    Indiana
    14,101
    827
    4827
    Many years ago, I read a science fiction story that included the hero arranging some nearly infinitely strong and nearly infinitely thin material across a doorway. The story said a villain trying to walk through the door in a hurry would cut himself in half. I guess the flaw is, how do you attach the material at the ends so that it does not cut through the attaching points.
    Larry
  13. #10
    Oct 2010
    Dewees Texas
    3,512
    37
    1164
    If the intent is a slow motion girdling with the tree eventually falling probably not. We see fences attached to trees by the lazy and the bark and wood will eventually grow around the offending wire.
    Weed eaters commonly girdle trees and the tree will eventually die as the roots starve. I have purposely girdled brushy thorn trees with flames from a pear burner, sprayed with a combination of gas and diesel, as well as skinned the bark off with a shovel all the way around the trunk. Takes several months to see if you did it successfully.
  14. Likes GregSY, sfriedberg liked this post
  15. #11
    Jan 2007
    Flushing/Flint, Michigan
    11,114
    665
    8890
    Quote Originally Posted by PackardV8 View Post
    Yes I have this. Seemed like a great idea at the time.
    But no bottom cut .... Bad.
    Bob
  16. #12
    Apr 2004
    Modesto, CA USA
    8,950
    1775
    You can cut pvc pipe with nylon string.
    Bill D
  17. #13
    Nov 2020
    Alabama
    98
    35
    58
    If you stretcheth thine wire betwixt two lightly laden swallows, yes, provided velocity is sufficient of course.
  18. Likes Billtodd, matt_isserstedt liked this post
  19. #14
    Jan 2002
    West Coast, USA
    9,349
    613
    6826
    Quote Originally Posted by edwin dirnbeck View Post
    Just wrap it with nichrome wire.
    Apply voltage . . .and burn through the cambium layer.
    Then wait . . . and wait . . . and wait . . . for the tree to fall.
    More seriously, there are several ways to girdle a tree -- and leave it dead and standing (for a while). If you prevent the entire cambium layer from transport, the tree will die.
  20. #15
    Nov 2013
    7,820
    6494
    6918
    Quote Originally Posted by L Vanice View Post
    Larry
    Have you ever seen the movie Cube? In this Sci fi/horror movie a bunch of strangers wake up in a strange maze made of cube shaped rooms with hatches to other cubes in all six faces. Sometimes the neighboring cube is ok, other times there are various deadly booby traps. In one room, the guy goes through and at first he seems fine but then a series of bloody lines appear and as the viewer realizes he's literally been diced by tiny invisible wires the pieces fall apart.
  21. #16
    Oct 2005
    22,784
    I think that was also a book by Scott Adams......
  22. #17
    Jan 2005
    Houston
    7,328
    1426
    4324
    I've heard of that cutting PVC with fishing line. Every time I've tried it (twice?) it didn't work 'worth a shit'. That's understandable as I usually am inept at just about everything except The Addams Family pinball and masturbation. But here's the kicker - every time someone else has told me you can cut PVC with a fishing line, then tried to actually show me, they also failed. What's up with that...? I file this tip under 'MacGuyver'.
    Around here, no one cuts down trees with anything. They use a big Komatsu excavator to push them over. Apparently, this takes care of the root ball problem as well.
  23. Likes fusker liked this post
  24. #18
    Oct 2010
    Oregon
    5,879
    5887
    2284
    Wire sawing, yes. Garroting, no, at least with actual wire rather than something out of a science fantasy. It is a common practice to pull stumps with a choke loop around the trunk. Exceeds the tensile strength of the soil (massively amplified by the root system) long, long before it squeeze the trunk to splinters.
  25. #19
    Jan 2011
    Michigan
    250
    127
    Quote Originally Posted by PeteM View Post
    Yes. More explicitly the disrupted cambium will starve and thereby kill the roots. This will in turn, stop water and nutrients from reaching the leaves which then kills the tree.
  26. #20
    Jun 2019
    864
    381
    958
    Quote Originally Posted by GregSY View Post
    Any chance the 2 are connected?
