Gear cutter number standardisation
Results 1 to 8 of 8
    Aug 2011
    Oregon
    2,580
    595
    784
    Default Gear cutter number standardisation
    Range of Cutters for Involute gear cutters Cutter Number Cuts Gear from
    1 135 teeth to rack
    2 55-134
    3 35-54
    4 26-34
    5 21-25
    6 17-20
    7 14-16
    8 12-13
    The above seems to be the western standard, but Chinese cutters seem opposite to me, which makes me wonder about their standards. I bought a number 2 cutter to make a 127 tooth gear but when I asked the Chinese seller if it was correct for that he said no, that I needed a number 7.
    I ended up buying three cutters from Victor machine traders company, a #2, #3 and a #4, and have no idea where the cutters were made, but OTH I'm having to pay two or three times as much as I would have buying direct from the Chinese.
    American gear manufacturers apparently decided some time ago that 14 DP and 18 DP would no longer be offered, nor cutters either through standard tool distributors.
    So, have other guys seen what I think I've seen, that Chinese cutter numbering is backwards?
    parts
  2. Likes rustdreamer liked this post
  3. #2
    Mar 2005
    near Rockhampton, Queensland, Australia
    5,559
    443
    2087
    Yes I have bought a chinese cutter but realised before I bought it that their numbering system is arse about face.
    It had me confused at the start as well...
    Mar 2008
    FINLAND
    209
    36
    136
    Seems like US standard is once again reverse from rest of the world (no offence here, just wondering..)
    In module pitch (which is probably the most used standard in the world) smaller the cutter #, the fever teeth count it is for.
    Checked some of my cutters and they are numbered like this:
    These are mostly old German, Japanese and Finnish made quality tools, none of them are chinese.
    #1 12-13T
    #2 14-16T
    #3 17-20T
    #4 21-25T
    #5 26-34T
    #6 35-54T
    #7 55-134T
    #8 135-Rack T
  5. Likes grg12 liked this post
  6. #4
    Aug 2011
    Oregon
    2,580
    595
    784
    I got the impression English standards are the same as ours. Maybe it relates to Inch or "Imperial" measurement? I can see how that might have confused the Chinese.
  7. #5
    Oct 2014
    UNITED KINGDOM
    703
    242
    350
    You can also find cutters labelled #0 to #7 and you can often find them in half sizes (usually for larger sizes)
    e.g.
    #1 - 135 to rack
    #1.5 - 80 to 134
    #2 - 55 to 79
    #2.5 - 42 to 54
    #3 - 35 to 41
    #3.5 - 30 to 34
    #4 - 26 to 29
    #4.5 - 23 to 25
    #5 - 21 to 23
    #5.5 - 19, 20
    #6 - 17, 18
    #6.5 - 15, 16
    #7 - 14, 15
    #7.5 - 13
    #8 - 12
  8. #6
    Jan 2005
    CANADA
    Saskatchewan
    10,238
    1397
    3696
    There is a formula used in cutting helical gears on a spiral milling setup. I don't have it handy but it had to do with which cutter you chose when milling because of the way the cutter cuts a groove slightly wider than itself. The formula involved the cube of the cosine of the helix angle, and the result when rounded off told you which cutter number to choose. So the cutter numbers aren't just numbers!
    It occurred to me that the numbering system might be inverted for module since diametral pitch is kind of inverted compared to module.
  9. #7
    Nov 2003
    5,428
    188
    1813
    I hadn't noticed that, but it is good to know. I will be on the lookout whenever I buy gear cutters.
  10. #8
    Dec 2009
    South Yorkshire, England.
    370
    566
    30
    I have a selection of British DP cutters, they follow the OP's standard of the smaller the number closer it is to a rack.
    Steve
