I'd like to repair a few gear teeth with bronze, which will require re-profiling them to remove the excess bronze. The gears are 10DP with a 20-deg. pressure angle and metric involute cutters are less expensive than Imperial. The repaired gears need to mesh, of course, but they operate at relatively low speed and don't carry large loads. My question is, how close would the tooth profile be with an M2.5 (equivalent to DP10.160) rather than a 10DP?
