Hoping you experts can help with some advice.
I have a 10" Logan lathe that did not come with the original gears. Imperial threading works just fine with the gears it came with, even though they are not stock gears. However, it did not come with the change gears for metric threading. So I set out to make some. Bought a DP16 gear cutter set, made myself an arbor and 2 gear blanks and went to town.
Now the problem, I mis-aligned one of the gear blanks when I set it up on the mill. The gear blank was offset on the rotary by 10-20 thou. So after I was done cutting the whole gear, I noticed the lands between gear teeth on one side were smaller than the other. Dumb mistake.
I don't have any more stock for making another gear blank, I would have to go buy some. But I was wondering if it is worth it. Am I overthinking it? Would the gears run just fine? (it's only 1 of the 2) The bore and OD are concentric, I just cut one side deeper than the other.
Don't have much experience with gear making and appreciate any advice.
Jared
Jared
