Anyone with experience running these machines is welcome to chime in.
The gear I was hobbing was helical. After my first pass, I realized my hob was positioned incorrectly when I noticed the hob was cutting with partial teeth. Time to shift the hob. In shifting the hob, I noticed that the part was rotating - I don't remember that happening with this or any machine. Of course, the part rotates while rapid feeding vertically. The machine uses change gears and is not CNC.
In the case of cutting helical gears, I'm assuming that the hob and the part remain aligned while side shifting. I know the hob doesn't remain aligned when side shifting the hob cutting a spur gear.
My question is: is the table supposed to rotate while hob shifting and the machine is at a stand-still? I couldn't find anything in the Operator's Manual.
