Gear pinion manufacture
Results 1 to 11 of 11
    Nov 2019
    CANADA
    Alberta
    Default Gear pinion manufacture
    Hi all, I'd like to make some of these small pinions in house possibly, BUT, i don't understand gear terminology or exactly what I'd need to order hob-wise to do so. No I don't have a hobbing machine but I do have a lathe and milling machine and a will to learn. Can anyone assist me with how I tell my pressure angle and pitch...a bit confused with the online data.
    Thanks, Chris
    Apr 2012
    Massachusetts
    119
    13
    17
    Unless you have a dividing head that can be hooked up to the mill table lead screw, you will need a gear hobber. It's necessary to do a helical gear, unless you have a CNC mill with a 4th axis, it would be possible then.
    Jul 2004
    Houston, TX USA
    29,746
    Helical gear - way more to it than that.
    Handy chapter on the subject in here - from 103 years back:
    A treatise on milling and milling machines .. : Cincinnati Milling Machine Company : Free Download, Borrow, and Streaming : Internet Archive
    Here is a start, but you need the mating gear ALSO
    ON EDIT...add a page from one of Earle Buckingham's gear books
    Attached Thumbnails Attached Thumbnails helix-angle-suit-center-distance.jpg   helical-math-.jpg
    Nov 2019
    CANADA
    Alberta
    Quote Originally Posted by johnoder View Post
    Excellent, I have all the parts and the gearbox, I'll do some measuring and see what I can come up with
  5. Likes Dumpster_diving liked this post
    Dec 2012
    AUSTRALIA
    2,068
    9
    625
    A pinion with a small number of teeth is certain to have a modified tooth form,and while I am sure you could cut a meshing component,it would be very noisy in operation,and fail quickly..........The other issue is wear on larger gear.
  7. Likes Dan from Oakland liked this post
  8. #6
    Sep 2005
    Oakland, CA
    2,450
    263
    656
    With all due respect, that is not a gear you want to be cutting with a dividing head and a space cutter. I commend you for wanting to give it a go, but you will not be happy with the end result. Turn up your blanks and take them to a gear shop that has the correct equipment to cut the teeth.
  9. #7
    Nov 2019
    CANADA
    Alberta
    yes, it's starting to look that way unfortunately gear shops are far and few between in Alberta and the lead times are brutal...time to search the auctions!
  10. #8
    Aug 2012
    California, Central Coast
    3,529
    2187
    1366
    How often do you need to make this gear? Is it a common wear part?
  11. #9
    Apr 2010
    Wisconsin
    6,057
    4178
    3712
    I hesitate to ask, but why does it have to be Alberta?
    Why can't you have it sent from Calgary or Edmonton? ( or anywhere else, for that matter? )
    There is A LOT more to making proper and good gears than simply investing in a machine. Forget the knowledge, how will you gauge them? Unless you are going to be making a lot of them, you will be miles and money ahead to farm it out to someone that knows what they are doing and can provide quality. You have at least two gear shops that are likely not even in the running ( due to the cross border costs ) advising you to farm it out. Might be free advice, but certainly worth more than it cost you.
  12. Likes Peter from Holland liked this post
  13. #10
    Jan 2005
    The Netherlands
    5,754
    267
    1452
    If you send it out be sure to send the mating gear with it
    Peter
  14. #11
    Dec 2012
    AUSTRALIA
    2,068
    9
    625
    I needed two gears from a mobile crane gearbox made......took it to the local gear place.....they said "it will be $1500 up front.....for us to do the calculations and prepare a quote ".....So ,I got out my Machinerys Handbook ,figured out what could be fitted,then went round all the truck and machinery wreckers and found a combination of gears that could be fitted....This was in 1994,the setup I made from truck gears lasted ,and now the old crane is likely to be scrap......took the gears out,and they are still perfect ,none of the welds have cracked ,the crane could go another 30 years......except for a thing called "Cranesafe",another cost to business ,bet there is no cranesafe in China or India.
