Gears centre distance problem.
Results 1 to 10 of 10
    Feb 2012
    usa
    9
    Default Gears centre distance problem.
    Can I calculate the gears centre distance without meshing
    measuring from gears teeth .when our gears size increases
    Or decrease from standard size.
    Jul 2004
    Houston, TX USA
    30,455
    Add the two pitch diameters and take half of that - which will be center distance
    Example:
    4DP 48 teeth and 4DP 96 teeth
    Have 12.000 and 24.000" pitch dias.
    12 plus 24 = 36
    Half of 36 = 18.000 center distance (if straight cut)
    Gets more complicated if helical
    Jan 2014
    Utah
    600
    1497
    257
    Quote Originally Posted by johnoder View Post
    Example:
    12 plus 24 = 36
    Do you need to add a wee bit of clearance?
    Jun 2001
    St Louis
    18,202
    1957
    3090
    Quote Originally Posted by Yan Wo View Post
    I thought clearance was in the tooth form, and that using center distance is kind of a make-do.
    Is that wrong?
    Mar 2017
    200
    99
    For a given module (or dp) and the total number of teeth in both gears there is a theoretically correct center distance where the two pcds are tangent. This is not an approximation.
    Module = ( 2 * cd ) / ( # of teeth in both gears)
  6. Likes Hopefuldave liked this post
    Jul 2004
    Houston, TX USA
    30,455
    Quote Originally Posted by JST View Post
    Is that wrong?
    Covered in infinite detail in Earle Buckingham's books - and others no doubt
    Apr 2018
    3,761
    1690
    Is that wrong?
    Yes and no .... Thinning the teeth by cutting them deeper is perfectly acceptable, and it doesn't mess with the shape because all gear machines now generate the shape, and an involute curve is not picky.
    If you were using a space cutter, it probably would not be perfect but space cutters aren't perfect anyhow and the teeth aren't a perfect shape under load either, so in practice, no.
    If you were doing cycloidal teeth then they'd be all messed up if you tried to cut them deeper to make backlash, it has to be in the cutter ... so in general, people don't cut cycloidal teeth, it's too much of a pain in the ass
    For those non-involute weirdo shapes you'll have to ask Zahnrad, he likes that ... stuff
    For the op's original question, I think the easiest way for him would be to do a span measurement and compare to standard dimensions. He could do it over wires, too, but that's more involved. The 'calculating center distance by counting teeth and dividing by the dp' method works okay if both gears are standard proportions. If they are drop-tooth or spread centers or in some other way non-standard, then the theoretical numbers won't work.
    Unfortunately, non-standard in the gear world seems to be kind of standard
    I think something that confuses people is the way we speak of theoretical things as if they were real. The fact is, gears do not have a pitch diameter until they are operating with another gear. And then, the pitch diameters are a function of the center distance and the numbers of teeth, not whatever the theoretical numbers are. It makes it easier to discuss but in Real Life (tm) the "pitch diameters" are almost never going to be the catalog numbers.
  9. #8
    Jul 2004
    Houston, TX USA
    30,455
    One of the old time "wire" makers - who always managed to load up their catalogs with great related info
  10. #9
    Aug 2008
    near Cleveland
    837
    65
    109
    I always follow these gear discussions with interest.... it seems like there's always at least *some* sorcery involved.
    Thanks.
  11. #10
    Apr 2010
    Wisconsin
    6,153
    4218
    3826
    Quote Originally Posted by EmanuelGoldstein View Post
    Hey! We do more Involute than not, but yeah... we do see more than our fair share of oddball* stuff.
    Most likely, it's only because I'm the only one stupid enough not to say, "No" right out the gate.
    *- Asymmetrical Tooth Forms and A LOT of Skip Tooth / Skip Space / Specific Alignment callouts / Non Standard Pitch Sizes ( ex: 14.56 DP or 1.19 Module ) / etc...
    This. So much this. People really don't realize how true this is.
    To the OP's question, as EG said - your answer is, "Yes." And, "No."
    Assuming we are discussing Involutes, it really depends on whether one, the other, or both are Non-Standard. The other variable that exists is by how much EACH, INDIVIDUALLY are non-standard.
    Is it backlash? Is it tooth Profile Modification? Is there a balance to the modification? Or, just one sided? And then, WHICH Van Keuren standard was used to measure them? ( which is actually one of the reasons that I like Span measurements - No effing around with figuring out what wire size to use. )
    Believe it or not, there is actually a few pages dedicated to this in Machinery's Handbook. ( among a host of others )
    This, combined with the previous answers is all you need to calculate the Center Distance. The biggest hurdle is being sure that you know HOW the gears differ from Standard.
